Volks AutosAH Fabrications
    Mar 2008
    79
    Need helps. Does drive shaft need to be refit by AUDI??
    Ok, as the topic says. i fit my milltek exhaust turbo back.
    as to fit this exhaust the drive shaft need to be remove.
    after we fitting everything back on.the car drives fine, but only above 100km on the free way the car shakes aibt.
    do i need to ask Audi to refit the shaft or they just bolt back on. are there any adjustment need to be done when the shaft put it back on??
    26,720
    I would double check the shaft fitment fella, you should be able to do yourself
    Iggu's Avatar
    May 2008
    Here
    1,224
    This thread may shed some light on it - if you haven't changed the mounts. Milltek Cat- back full system problems...
    Phantom Black S3, RNS-E with SDS Hack , BOSE, Sunroof, iPod, ITG CAI, Forge DV, Milltek TBE, Revo Stage 2+, Autotech HPFP, Sachs clutch, Lamin-X, BBS Pescaras, H&R springs, H&R ARBs, NGK Iridium Plugs, Vagcom.
    Khufu's Avatar
    West coast of Scotland
    5,693
    I know drive shafts are often balanced so they need to be put back on by lining the holes so they all match up with how they came off. When I did it on my old BMW I marked the joint with tipex to ensure this. Could be same with S3
