EM TuningAH Fabrications
Thread: Tyre pressure
    Oct 2007
    6
    Tyre pressure
    I own an A3 sportrtback 2.0T Quatro. I have changer my rims, and fitted those of an S3 with the standard 225/40/R18 dimensions for the tyres, But im not sure about the air pressure. Does anybody know how musch should I inflate them?
    Dec 2006
    Ireland
    2,538
    have you looked at the sticker inside your fuel flap?
    Oct 2007
    6
    yes but it doesn't have an option for tyre over 17"
    Jul 2008
    cumbria
    255
    Im curently using 38psi front and 36psi rear but mines an s3, i suppose if yours is a quattro then the weights should be similair so you could try those pressures.
    aristides's Avatar
    Aug 2008
    Greece
    543
    Quote Originally Posted by block View Post
    Wow that sounds a lot to me!!! Maybe cause its an S3.
    I got a 1,4T with 225x45 R17 and because here in Greece its extra hot i have 30 front and 27 rear!
    I tried once to use 35/30 but the car was awfully bumpy!
    FOR SALE:
    RNS-e 2013 DVD, BK Version, NOT unit, DVD disc
    Steering ECU : 1k0 953 549 AH, ideal for Cruise Control retrofit
    Jul 2008
    cumbria
    255
    Quote Originally Posted by aristides View Post
    it is because the s3 is a heavy old lump.
