AH FabricationsVolks Autos
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    indicator bulb change- how?
    Hi All,
    Sure this has been covered but is there a quick way of changing the front indicator bulbs (on xenon hd lights). I heard its in the arch but do you have to take the liner out?.
    Porsche 997 Carrera 4 S - Black, Sport Chrono, Sport seats, PCM, Nav, Tel, Park assist and rear wiper (Yes!, its an option!)
    2012 Audi Q7 Sline Plus - Daytona Grey ,Nav+, Wheel upgrade, Storage and tow pack.
    Gone -2007 S5 4.2 ,2008 S3, 2007 TTC 3.2, 2007 RS4 Saloon, 2004 S4 Saloon, 2006 A4 2.0T Sline SE,2002 A3 3.2 Sline, 2001 A4 1.8T,2001 Boxster, 1983 911SC,1992 Corrado G60,1988 GTi.
    (Vag com owner)
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Some members have been able to get to the indicator bulb from the bonnet but I certainly couldn't.
    I went for the wheel arch route - you don't have to remove the liner completely, just the bottom 2 torx screws nearest the side of the car and the middle ones. You should then hopefully be able to peal the arch back enough to get your hand in and feel the indicator bulb housing - I'm pretty certain it was a twist out bulb holder.
    Jon
    Now A3 less......
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    This depends on what xenons you have, the bi-xenons are do-able within the engine bay, the non bi xenons you will need to go through the arch.
    jamiekip
    As Robin said, I managed to do mine (bi-xenons) and I ahve hands like shovels... it's a bit of a squeeze, but you can manage - took me max 5 minutes to do both sides.
    Good luck
    The911SC's Avatar
    Sep 2003
    1,032
    thanks guys; i'll give the in the bonnet route a try first!.
    (Vag com owner)
    The911SC's Avatar
    Sep 2003
    1,032
    Done... Removing the plug for the xenons make it pretty easy..
    (Vag com owner)
