Results 1 to 15 of 15
    Brookie-S3's Avatar
    Wakefield
    67
    S3 Rear Diff noise
    Hey all
    since i got the car ive heard a bit of rear diff noise and i think its getting worse.
    took it down to leeds audi where i used to work and went out with a tech who also heard it.
    if you do 75mph, and back off the throttle then on very lightly there is a whine there, rather annoying as this is mostly my crusing speed on the motorway
    its booked in on wed for them to check
    anyone else noticed this ?
    I cant spell !
    Jun 2007
    North West
    434
    Not noticed this but I would be very suprised if its the rear diff as I would have thought at 75mph its would be mostly fwd (unless hard accleration say through a bend) on a motorway.
    My money would either be on the exhaust moving on its mounts and causing a whine / rattle worse when taking left bends on its mounts (which mine had to recently go in for) or a rear bearing ?
    Would be interested to know the outcome
    Richard
    MY12 Black edition TT Roadster with a tractor engine !
    Splathead's Avatar
    Dec 2007
    Suffolk, UK
    186
    Yep, I've noticed a whine at exactly 75mph on a constant throttle in mine as well. Any faster or slower and it disappears. I noticed it the day that I picked it up. I just turn the stereo up or change speed.
    I'll be interested to know what you find out.
    Present - 8V S3 3 Door S3 S-Tronic. Estoril Blue, LED Headlights, Super Sports Seats, Technology Pack, Folding & Dimming Mirrors, Interior Light Pack, Bang & Olufsen, Comfort Pack with Cruise Control & Rear Parking Sensors, Reversible Boot Liner, Tyre Pressure Monitor, Non Smoking Pack, Hold Assist
    Past "Highlights" - 2008 S3 (8P2), 2004 Alfa 147GTa, 1999 Fiat Coupe 20v Turbo LE, 1994 Astra GSi 16v
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by rsarjantson View Post
    I'm confused by this statement.
    Surely the diff still works (i.e.its internal rotate), even if no drive is getting to it?
    The rear-wheel driveshafts must still rotate with the wheels, which means the differntial gears must rotate in the differential housing?
    Okay, they are just 'freewheeling', but they're still moving?
    So there is still a chance of noise?
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Aug 2007
    somewhere
    796
    Might be Wrong?
    I recently had an S3 and too noticed a rattle type noise at certain speeds, especially in 5th and 6th gear, between 4k rpm and 5 rpm, found out that it was the plastic nut that secures the spare wheel in place! could it be that?
    Khufu's Avatar
    West coast of Scotland
    5,693
    Quote Originally Posted by bowfer View Post
    I agree, unless wheel spin, the front and back should rotate at the same speed. Maybe he means the noise only come on under load?
    I cant spell !
    Jun 2007
    North West
    434
    D'oh me been stupid - of course they are still rotating
    - If its doing it at a certain speed would suggest something out of balance much like wheels / tyres out of balance vibrating a certain speeds.
    Richard
    Brookie-S3's Avatar
    Wakefield
    67
    i used to be a tech at leeds audi
    its nothing rattling round in car or the boot
    its not a wheel bearing as it does not increase with load around corners.
    the rear diff rotates the same speed as the front, its 4 wheel drive !
    its defo the rear diff at 75mph, only on very light throttle i can get it to play a tune if lift of throttle then back on lightly........
    not tyres out of balance
    JohnS3's Avatar
    Oct 2004
    3,021
    Mine does this too, would like to hear how you get on though.
    JohnS3's Avatar
    Oct 2004
    3,021
    Bump. Any news??
    SiT
    Apr 2008
    Tyne & Wear
    98
    I get this also.
    For a little comparison, i used to get this on my MkV R32 which is a similar setup to the S3. I did find it more pronounced in the R to my current S3... but it is there all the same.
    S3OPES's Avatar
    May 2009
    19
    I have this same problem but it does when i'm coming off the throttle from high revs. did you get it sorted. Or has anyone discovered the cause yet?
    8P SILVER
    SiT
    Apr 2008
    Tyne & Wear
    98
    Its still happening on mine too, although looking at my post from Sept last year, it IS now more pronounced then my R32..! It's been to the dealers a few times now, the last with Audi replacing my Propshaft.
    In Toby C's thread though looks like he has had Audi to replace his rear diff. My car needs a service imminently; I’ll push again when it's in as the propshaft hasn't cured it, in fact i now get it at around 70mph.
    tobycruse's Avatar
    Jul 2004
    UK
    287
    Just had my diff replaced, the noise has gone. Have a look at this thread:
    Whining noise - Its the wheel bearing right?
    Who said speed kills!?!?....But dangerous driving on the other hand....
    Ibis White S3 Sportback - ?bhp - ?lb/ft (Being Fixed)
    Mods: LED's Throughout, Milltek TBE, Revo S2+, Forge CAI (Gold), K&W V3's 25mm, H&R ARB's, Powerflex Bushes, Autotech HPFP, Sachs Clutch, Forge DV, Jonny's PCV Mod, Defi Boost Gauge, Pro Alloy Intercooler, 18" OZ Alleggerita's, NGK Iridium Spark Plugs, VI Performance Monitor, Road Angel Pro Connected
    Full OEM Springs and Shocks for sale from 2008 S3 CLICK ME
    kinson's Avatar
    Mar 2009
    Hong Kong
    73
    Glad that I found this thread...
    I notice the clinging noise coming from the rear left recently. The noise appears when the gear is engaged and foot off the throttle. Noise disappeared gear is moved to "Neutral" (disengaged). I suspect this is something to do with the differential, instead of the wheel bearing, and after reading this thread, I'm more confident it is not the wheel bearing. The only thing is whether the rear differential refers to the Haldex unit? Is the whole Haldex unit required to be replaced?
    BTW, I'm driving a MY 2009 S3 Sportback (8PA).
    Jul-09 :audi: S3 Sportback (8PA)
    Haldex 4 | Witness | KW V3| MFBSW | DVN-A3 | VR G2 | PSS | Recaro OEM Buckets | Stinger DSI | Alcon | Forge DV | MTM Full Exhaust & ECU Remap
    Gone: GC-05K | PS2 | STi-R | ZR4 | Bluefin | D-Spark
