I'mRonBurgundy?
Lets make that kitten purr...
- Joined
- Jan 29, 2008
- Messages
- 554
- Reaction score
- 0
- Points
- 16
They (the wiper arms) don't stop fully they just slow down when the car does and speed up again when the car accelerates.
Shouldn`t they react to the intensity of the rainfall and not just the speed?
The speed sensitive bit is annoying at times in heavy rainfall, if you go from 60mph to 15mph quite quickly, they slow right down but the rain does not slow down! Normally when speed changes like this it's because your at a junction / roundabout etc, so the ability to see out of the windscreen is quite important!
But instead the wipers don't wipe for a few seconds, and your left fiddling with the stalk so you can see!
the reason they don't come on when you turn on the ignition if you removed the key with the wipers set to on is in case there was a hard frost and your window is frozen over - it prevents the wiper motor from burning out if the blade is stuck to the window. I believe it explains this point in the manual.
I don't think I've ever left the wipers in the on position when parking. maybe that's just me!
i like the way when you blast the screen with washer fluid it does the last sweep much slower to make sure all excess has been wiped away, and i like the way when you are sat at a traffic lights it slows down.
Maybe that's just me though!
Personally never had that problem!
If I come to a stop then I am not catching as much water on the screen as I would be doing moving at speed so the wipers going to the next speed down stops from them from screaching and smearing like they would if left on the highest speed
