EM TuningSky Insurance
Results 1 to 8 of 8
    SiT
    Apr 2008
    Tyne & Wear
    98
    S3 Adaptive Xenon's
    Afternoon Chap's
    Doe's anyone have this..?
    My car supposidly has these and since i got it in May i haven't actually been out in the dark till last night. I couldn't see the beam turning as the steering wheel moved so wondering it it has them at all. i was travelling mixed speeds up to 60mph ish.
    I have my lights normally set to Auto and tried moving to its normal switch position to no avail.
    Ta
    Si
    JohnS3's Avatar
    Oct 2004
    3,021
    If you start the car (and the lights are on), they run a self test and should dip to the floor and come back to level. If you also have the adaptive feature the lights should also move out to the sides and then back to straight ahead. I think someone posted a video of this a while back.
    JohnS3's Avatar
    Oct 2004
    3,021
    This is on a Seat, but IIRC it's a similar thing.
    EDIT:
    This is a 2007 Passat
    SiT
    Apr 2008
    Tyne & Wear
    98
    Cheers John
    Mine doesn't do that...the side to side bit anyway. I think i was mis-sold..!
    Is there any other way i can check..? Can i ring Audi UK or something to actually get the full spec of my car..?
    Feb 2008
    Europe
    231
    Mine works just like the video. First down/up then sideways and back.
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by SiT View Post
    Cheers John
    if you ask your dealer to print you off the data sheet for your car you it should list adaptive lights if you have them.
    alternatively if you look at the inside cover of your service book there should be a sticker with loads of 3 character codes.
    the ones for xenons are:
    8BP = Xenon
    8EC = Bi-Xenon Linksverkehr
    8ED = Bi-Xenon Rechtsverkehr
    8EJ = Bi-Xenon Linksverkehr "J.."
    8JG = Xenon Rechtsverkehr
    8JJ = Xenon Linksverkehr
    are any of these codes on your list?
    maxS3uk's Avatar
    mike
    Feb 2008
    Lincolnshire
    112
    mine dont go up and down!
    Well only on the odd occassion. Are mine broken??
    26,716
    no not broken, they dont do this everytime, they adjust when you drive all the time anyway & you dont notice this mostly, dont worry they seem to be working if you do see them doing this on odd occassion
    just be aware, people's perception is that all Bi-xenon oem headlights also have the left to right option, this isnt true, there are 4 types of headlights in all:
    1: Halogen - Obviously standard yellow look
    2: Xenon - Dipped Xenon with auto levelling
    3: Bi-xenon - Dipped/Raised Xenon with auto levelling
    4: Bi-xenon plus/adaptive(known as with curve in europe) - Dipped/Raised Xenon with auto levelling with left to right function (configurable for opposite side driving with vag & 5052)
    All xenon headlights have the auto levelling system up/down & should always have the headlight washers as it appears to be law now I believe with xenons for some reason I dont know
    Auto & normal position wont make any difference to the left/right up/down system, these systems are switched on when the lights are on in either auto or normal setting on dial, need to get actual part number for headlights but you can also check the headlight control module as this indicates the lights installed as its different for adaptive/plus from normal bi-xenon & also the headlight levelling control module is different for adaptive/plus as doing mod from xenon to bi-xenon plus when got headlights
    If you have VAG & ETKA you can easily work out what you have
