Volks AutosMonster Motorsport
Results 1 to 13 of 13
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    S3 - bose- Speaker buzz
    Hi All,
    Just got back from the dealers. Car was in to rectify a buzzing speaker (rear right). The buzz is interference that changes with the engine and no audio output at all. The dealers ordered a new bose amp and speaker to be safe, fitted both but the buzz is still there.
    I know its not the head unit since I have an rns-e which i retrofitted, and re fitting the concert 3 unit gives the same.
    Any ideas?, the car is back in next week for them to take a closer look but I am stumped and wonder if I did anything in my retrofit?.
    Porsche 997 Carrera 4 S - Black, Sport Chrono, Sport seats, PCM, Nav, Tel, Park assist and rear wiper (Yes!, its an option!)
    2012 Audi Q7 Sline Plus - Daytona Grey ,Nav+, Wheel upgrade, Storage and tow pack.
    Gone -2007 S5 4.2 ,2008 S3, 2007 TTC 3.2, 2007 RS4 Saloon, 2004 S4 Saloon, 2006 A4 2.0T Sline SE,2002 A3 3.2 Sline, 2001 A4 1.8T,2001 Boxster, 1983 911SC,1992 Corrado G60,1988 GTi.
    (Vag com owner)
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    Sounds like a cable problem then if they have replaced the amp and it happens on two different sources.
    Was it OK before you retro-fitted the NAV ?
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    The911SC's Avatar
    Sep 2003
    1,032
    yes, but it was also ok afterwards. I am trying to think back at when it could have gone and I guess it may have been a similar time to me adding the cd changer lead (which is not connected yet) but ready to be. (unless I broke a wire on the multi block?)
    Its strange its just one speaker though if there is a cable fault?. Wouldnt it point to between amp and speaker?. Doesnt the bose work off a line in and as such would only have left or right out if there is a cable issue?
    I am going to feel bad if the dealer finds something I screwed up somehow?.
    (Vag com owner)
    Feb 2007
    Hampshire
    1,654
    The Bose has a F/R fade function so I believe that there are four line outs and it could just be that you have damaged that one cable in the loom.
    Paul
    VCDS HEX-USB+CAN
    The911SC's Avatar
    Sep 2003
    1,032
    Would that be from the Bose amp (which i havent touched) or the headunit?.
    I thought the headunit just had a signal out?.
    Thanks for your help !
    (Vag com owner)
    Feb 2007
    Hampshire
    1,654
    Head unit.
    I will see if I can find the wiring diagrams from the Bose system over the weekend.
    Regards,
    Paul
    VCDS HEX-USB+CAN
    EAGLE79's Avatar
    Nov 2006
    340
    If it is still the same as older car stereos then a part has broken down and the name will come to me in a minute!
    Basically it allows the enginereving to be transmitted throught he speakers. Heard and correctly fault found this a few times...
    My brain has gone dead on the part name come boy
    Give me time! LOL
    2008 S3 in Ibis White
    291BHP! STANDARD on 95ron Fuel. Get In.
    All Hail Mitch78
    The911SC's Avatar
    Sep 2003
    1,032
    Quote Originally Posted by EAGLE79 View Post
    (Vag com owner)
    Feb 2007
    Hampshire
    1,654
    Right the wiring diagrams aren't very helpful in that they don't give the signals on the pin outs - however you may find that the sat nav will have the pin outs on a label on it. Certainly the Concert from my 2005 A3 does.
    I doubt if it is the wiring between the amp and speaker as you wouldn't hear anything.
    Sounds like either the output chanel on the source (NAV unit) has gone or the problem is on the line level connection between the NAV unit and Bose amp in the boot.
    If you find that the nav unit doesn't have a diagram, I could send you a photo of the diagram from the top of my Concert as I suspect that they will be the same.
    Paul
    VCDS HEX-USB+CAN
    The911SC's Avatar
    Sep 2003
    1,032
    thanks... Its strange though that I get the same result from both the nav unit and the original concert unit though which would indicate that the head unit is ok ( or both blown with the same issue?). Anyone know where the cable runs to the bose, or where the bose amp is?.
    I have pin outs for the rns and concert as they are printed on the unit.
    (Vag com owner)
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    This happens in my 08 A3 with factory fitted nav...
    The911SC's Avatar
    Sep 2003
    1,032
    FIXED!. Thanks everyone who helped!.
    I took the multi block apart and pulled out the green connector, releasing the black insert, I found the green wire was pushed right back. I couldnt re seat it and pulling it out (despite using a pin to press the tang down) resulted in it snapping. I pushed it out from the other side with a paper clip and extracted the broken plug.
    I had some repair wires (the yellow ones with a clip at each end) so slotting a new one in, soldering it to the green and shrink wrapping it resulted in it all working..
    It made sense really thinking about it but HUGE thanks, its now sorted and all back together with the rns installed.
    This forum is just great to talk things through!, it really helps..
    (Vag com owner)
    Feb 2007
    Hampshire
    1,654
    Great news - glad you fixed it OK.
    Paul
    VCDS HEX-USB+CAN
