EM TuningBadger5
Results 1 to 13 of 13
    Feb 2004
    79
    Reversing Camera
    Hi All,
    I have been looking recently at fitting a rear view camera. I know that the A3 doesn't need one but it just looks cool!!!
    Anyway, technically it seems pretty straight forward, especially now that the reverse signal is carried over CAN, but..
    Where the hell to mount it without it looking messy?
    Any ideas, has anybody on here done this? any pics?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    Do you really have to change the cars coding to Lambo to get this to work?
    http://uk.youtube.com/watch?v=lCfrWP_JR60
    8P2 S3
    Dec 2006
    Ireland
    2,538
    no, i think you can do it with the audi coding now as there is a reverse camera available for the a4, r8 and q7.
    Feb 2004
    79
    yes, if you go into the RNS-E engineering mode, and select reverse gear you can see that it receives the reverse signal over the CAN Bus.
    I think that the A4 has the camera fitted in the boot handle, any idea whether this handle would fit an A3?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    Quote Originally Posted by spencerjoel View Post
    How do you do that?
    8P2 S3
    Feb 2004
    79
    when your RNS-e is on press Nav, to go to the nav screen, then press and hold the top left button (around the select knob) for 5 seconds then hold the top right one for 5 seconds
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    Cool! Cheers
    8P2 S3
    Jan 2007
    Hampshire
    1,155
    I put the Q7 camera into my A4 using an A6 boot handle. Looks and works perfectly without the need for it to be coded as a Lambo.
    A6 3.0 TDI.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    So how's it done? What coding? How much?
    8P2 S3
    Jan 2007
    Hampshire
    1,155
    Info here this was into an A4 but I believe it has also been done into the A3.
    A6 3.0 TDI.
    Kontraband's Avatar
    Dec 2007
    1,998
    going backwards isnt my issue... its backing in to the garage on the incline I have and the front being close to the fence... I could do with it like the BM's and there colours zoning for proximity...
    Front sensors I see are now an option on the FL S3
    Feb 2004
    79
    That camera looks great on the the boot handle, I just need to find out if the same handle will fit the A3.
    Am I right in thinking that the handle costs around 160? without the camera
    Jan 2007
    Hampshire
    1,155
    You could always pop to your Audi dealer and measure one up. I seem to recall a guy on navplus.us who installed on into an A3 - not sure if any mods were required though. I cant remeber the exact cost but around 160 (including the camera) sounds about right.
    A6 3.0 TDI.
