Volks AutosAH Fabrications
Results 1 to 9 of 9
    tobycruse's Avatar
    Jul 2004
    UK
    287
    A3 Interior Bulbs - LED Upgrade
    Very quick question. What are the fitments for the interior bulbs in the A3. I know 2 of the 6 bulbs are 42mm festoon. What are the other 4 bulbs, the base is about 10mm. This is to upgrade the inerior bulbs to a pure white led bulbs, they consume less power, emit no heat, and give a pure white light instead of that naff looking yellow light. Oh, if it helps i do have the interior lighting pack.
    Who said speed kills!?!?....But dangerous driving on the other hand....
    Ibis White S3 Sportback - ?bhp - ?lb/ft (Being Fixed)
    Mods: LED's Throughout, Milltek TBE, Revo S2+, Forge CAI (Gold), K&W V3's 25mm, H&R ARB's, Powerflex Bushes, Autotech HPFP, Sachs Clutch, Forge DV, Jonny's PCV Mod, Defi Boost Gauge, Pro Alloy Intercooler, 18" OZ Alleggerita's, NGK Iridium Spark Plugs, VI Performance Monitor, Road Angel Pro Connected
    Full OEM Springs and Shocks for sale from 2008 S3 CLICK ME
    tobycruse's Avatar
    Jul 2004
    UK
    287
    After looking around i believe its a 233 bulb. Can anyone confirm this?
    justandy's Avatar
    Not an S3 owner!
    Jun 2004
    West Mids
    29
    wouldn't bother,
    I tried LED bulbs, they just don't work quite right, they tend to glow when they are supposed to be off! Very distracting at night.
    Before you splash the cash I have a couple of the festoon bulbs you are welcome to try, pm if interested.
    Andy
    tobycruse's Avatar
    Jul 2004
    UK
    287
    Just fitted the new LED bulbs, work a treat. Bright white light and when they switch off, they are off. I know what you mean, i did have some blue leds and they would glow slightly at night, not a problem now!
    justandy's Avatar
    Not an S3 owner!
    Jun 2004
    West Mids
    29
    The ones I had just glowed when the car was runing PITA!
    Maybe the newer ones are better, I got mine about four years ago they worked fine in an 8L but not 8P.
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by tobycruse View Post
    Pics???
    8P2 S3
    Khufu's Avatar
    West coast of Scotland
    5,693
    I guess the LED would just glow as the capacitor for the delay system expects a set wattage, causing a timed delay, if the drain is lower then it will last longer.
    tobycruse's Avatar
    Jul 2004
    UK
    287
    I see what your saying regarding the time delay but I'm sure the delay switch off operates on a digital voltage reduction system. I say this because changing the blub to LED had no effect on the switch off delay. Imagine if it did, changing a 10w bulb to 0.5w, you would be there all day! The site i got them from is:
    http://www.autobulbsdirect.co.uk/led...lbs-c-589.html
    The LED's i purchased are:
    2 x 264 LED Extreme Power Festoon Bulbs - 42mm
    4 x 233 LED Quad Bulbs
    Will aim to get pics up asap!
