Monster MotorsportChris Nott
Results 1 to 16 of 16
    nhowroyd's Avatar
    Apr 2008
    ILKLEY
    128
    Enable DIS on an A3 with S-Tronic/ DSG gearbox
    Many thanks to MarcQuinlivan and mitch78. Marc for the instructions and mitch78 for the use of his VAG.COM and Computer.
    Marc some of the coding was slightly out but it gave Lee and myself the start point.
    Here are the instructions as to how....
    Section 1 - Vag Com - 5 minutes
    1) Plug and prepare the vag com through your cars diagnostics port
    2) Go to section 'Steering Column --> 16' and change your coding to 0011142.
    3) Go to section 'Instrument Cluster --> 17' and change your coding to 0000423.
    4) Once changes have been made, dissconnect the vag com, take the key out of the ignition and wait 10-15 sec.
    5) Turn the ignition on and wait for the idiot message to go away. You should now see that performing Section 1 will result in two things. One, the washer fluid empty icon May appear since some A3s do not have the sensor. Two, you will get the distance to empy readout.
    Nick
    July 08 - A3 Sportback SE 2.0 TDI 140 S-Tronic - Deep Sea Blue - Ipod - Aluminium inserts - TomTom Proclip mount - THB Bury Car Kit - DIS
    Dec 2006
    Ireland
    2,538
    Good job Nick. I assume you'll grounding the repair wire to make the washer fluid error go away?
    I think the coding on the notes I sent you was the coding for the car of the dude who posted the thread I mentioned.
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,721
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    Dec 2006
    Ireland
    2,538
    Indeed!
    nhowroyd's Avatar
    Apr 2008
    ILKLEY
    128
    Cheers Guys its SWEEEEEEEEEETTTTTTT.....
    Just found out that my neighbour knows an Audi mechanic who will fit the washer stalk for me and get it at his cost price..... Dude I am so happy...
    Nick
    nhowroyd's Avatar
    Apr 2008
    ILKLEY
    128
    Quote Originally Posted by MarcQuinlivan View Post
    No washer error came up so I gonna run down my washer and see what happens........
    Yea the coding was for a left hand drive car some where else... as when we did it it came up the passenger door was open but the drivers one was. Also there was the most annoying beeping coming from the car, some sort of warning tone..... Then also the Temp changed to F....
    But I am well happy with it.. I need to get a VAG.COM sorted now and get the stalk fitted..
    But once again cheers gents...
    Nick
    Aug 2008
    137
    Sorry to seem dense, but do you mean that, if I buy a used A3 (Sportback) SE without DIS specified but with DSG that I can just buy & fit a washer stalk with the buttons on and recode using VAG COM to activate DIS?
    Dec 2006
    Ireland
    2,538
    That's about the gist of it.
    mitch78's Avatar
    Mar 2007
    2,721
    Ex 8L S3 driver
    nhowroyd's Avatar
    Apr 2008
    ILKLEY
    128
    HELP!!!!!!
    Just fitted the new washer stalk and now have an ESP fualt flash up....
    How can I clear this.....
    Nick
    Jan 2007
    Hampshire
    1,155
    Clear it with VAG-COM, although sometimes you just need to take the car for a drive and the ESP light will go out. Mine did this after I had removed the steering wheel one time.
    A6 3.0 TDI.
    Dec 2006
    Ireland
    2,538
    The ESP fault is displayed because you would have had the battery disconnected while removing the airbag. You should also have a steering wheel light on the dash. Driving the car a short distance will clear the ESP light and you'll need to do the steering angle calibration thing too. The steering wheel light will go out at the same time as the ESP one, but he steering angle thing may need doing too. I've never done it, but some people might suggest that you should do it.
    nhowroyd's Avatar
    Apr 2008
    ILKLEY
    128
    Well now have the airbag light on now... Don't know about the steering angle calibration.... sure some one will let me know what to do..
    Nick
    Dec 2006
    Ireland
    2,538
    you'll need to clear the airbag fault using VAGCOM.
    nhowroyd's Avatar
    Apr 2008
    ILKLEY
    128
    knackers..... will have to sweet talk Mitch78 again or some other helpfull person
    Nick
    nhowroyd's Avatar
    Apr 2008
    ILKLEY
    128
    Thanks to Mitch78 and his Vag-COM lead I am now sorted....
    We also did a bit more coding as well...
    Nick
