Volks AutosSky Insurance
Results 1 to 24 of 24
    Apr 2004
    1,139
    climate control glitch
    Anyone ever had climate control stick on econ mode (ie, AC switched off) - had this today, thought, its gettin bloody warm in here, and couldnt feel cold coming out of vents event tho temp on 19, then looked down and econ light was on, but when i pressed it, the light went off only while i held the button in, once released it the light was on again. Stoped my engine at some red lights and restarted and it worked again
    Anyone had this? Is it trying to tell me something??
    Jay.Ing's Avatar
    Jun 2008
    Southport
    224
    2012 A3 Ibis White SportBack Black Edition 140
    Mods so far: H&R 50mm, RNS-E, Cruise control, Interior OEM LED mood light, OEM LED number plate lights, OEM LED Puddle lights, OEM LED Footwell Lights, tear drop wiping, Beep confirm on close, pressed plates, HHA & TPMS.
    Mods to come:light/rain sensor (In progress), and so on........
    Gone But Not Forgotten....
    2011 A1 Black Sline 106
    2006 A3 Red Sline 140
    Kitsch's Avatar
    Seat - Skoda - Audi
    May 2007
    Southampton
    20
    Yes I had the same problem much on a hot day like these, apparently a stone had punctured the A/C radiator (you could see the damage). cost to repair 750 so I claimed under insurance 250.
    A3 Sportback, Lava Grey, S-line, 2.0 Tdi 170, S-Tronic, MFSW, Bose, Symphony II, Rear Parking Sensors, Heated Front Seats.
    Apr 2004
    1,139
    well - ive only notice it happen once, could this be a one off or is it pretty conclusive that once is enough and it will happen again... i know exactly why it would happen however, car has just been repaired following a minor front end bump - main radiator and some other parts were replaced, and i know from the invoice the ac was re-gassed, so obviously there was some damage to the ac system also.
    Apr 2004
    1,139
    got to the bottom of this - had an ADT out today from roadside assist, and they have confirmed the pressure in the system is too high - 29bar and should be 10bar with engine running apparently, so its causeing the system to shut down to prevent damage. This is obviously an issue with the recent repairs i had done where the ac system needed regassing. Just don't know why people can't follow the book wiht these things raqther than just guessing!
    Khufu's Avatar
    West coast of Scotland
    5,693
    maybe they gassed it to the 8L requirements. kwik fit did it to somebody else on the forum already....
    Apr 2004
    1,139
    does the 8L take more than 525 grams then?
    Khufu's Avatar
    5,693
    according to Autodata, 8L takes 775g(+-25) and 8P takes 525g(+-25)
    Apr 2004
    1,139
    perhaps thats whats happended then - but whatever happened its resulting in more than double the pressure in the ac system than what should be there.
    Apr 2004
    1,139
    well took it back to the garage and they re-gassed it based on what i told them about what the ADT said - and hey presto on way home from work today and econ light stuck on again - so over-gassing is not the problem
    Anybody clued up who knows what this could possibly be?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Have a read of this:
    http://audi-sport.net/vb/showthread.php?t=57270
    then give me a shout
    8P2 S3
    Apr 2004
    1,139
    yep read it all - all exactly whats happening - had the system emptied vacuumed out and refilled with exactly 520g of refridgerant - i watched the guy do it, so its got the right amount of gas in it - but for some reason it is still tripping out and is going into econ mode
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    It could be fault high or low pressure sensor. Or the compressor itself, but not so likely with those symptoms. Have you got access to vag.com? If the HP or LP cutout was either at fault or simply kicking in there should be a log.
    To be honest I would say that the fault was caused directly from the repair or indirectly from it being over pressurised!
    8P2 S3
    Apr 2004
    1,139
    hmmmm - well when the ADT put his computer on it (vag com i presume) he said it had logged a fault of overpressure, ie, it was hitting the 29bar threshold the sensor can read and then the ECU was shutting the system down - causing to go into forced econ mode.
    balls.... i can see this being a back and forth affair - as some days (cooler days) the ac seems to work ok enough for the garage to not see a problem, yet i get a wet damp muggy day the day after and im sat in a car which is misting up to the hilt inside and getting really warm
    They are trying to say its prob a seperate issue with the console in the dash but come on.... what kind of coincidence is that, after a small bump, suddenly start havin issues with the ac
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Yes if the car was logging the pressure cut out before then you need to get it looked at this time for sure. That's the first step in the fault diagnosis. Where abouts are you?
    If you want to replicate the fault on a cooler day you could try turning the temp down to Lo and turn the fan speed down. This will increase the pressure in the system. A normal system should be able to cope with that though.
    The fault should still be logged anyway so this should be necessary unless you clear the faults then do it to make sure you're reading the right data.
    8P2 S3
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    Quote Originally Posted by Kitsch View Post
    That really annoys me, why don't manufacturers put mesh in front of the vulnerable evaporator to protect it. Might be worth thinking about.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Quote Originally Posted by A4Quattro View Post
    I just went to have a look at which radiator is positioned where. It's quite hard to tell but it looks like the engine cooling radiator is at the back and the condensor (not the evaporator as that's in the dash) is at the front. The intercooler should be at the bottom correct? They have to put them that way round as if the radiator gets hit you break down, rather than just lose air con. But a mesh would be a good idea yeah.
    A lad I know has taken the lower grille off of his GTI Ed30 because it "looks better".
    8P2 S3
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    Quote Originally Posted by staz1000 View Post
    Yeah sorry, I realised my mistake, its the condenser at the front, the refrigerant gets cold when it evaporates and warm when it condenses..doh!
    The intercooler is normally off to one side, on my A4 it was in front of the NS wheel.
    Chris
    See my images @
    Felix A3's Avatar
    Apr 2008
    23
    There might be a blockage in the system.
    Its not unusual for the dessicant bag in the receiver dryer to break up and you end up with balls of dessicant spread throughout the whole system. It tends to block up the TX valve first (or orifice tube) which then causes overpressure in the system.
    Apr 2004
    1,139
    nope none of these! turns out the fuse for the fans had blown and hadn't been replaced, ie, i'm driving around with no fan function at all unbeknown to me - what a stupid mistake to make by a garage which could ultimately cause engine damage (although pretty unlikely im told on a diesel)
    As i said earlier, why can't these places do the job properly?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    I talked about the fans in the FAQs thread I posted Steve.
    I assumed you had checked the fan was running.
    8P2 S3
    Apr 2004
    1,139
    well yes but i presumed the 'highly-trained audi technicians' wouldn't have missed such a simple thing as this
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    But of course!
    8P2 S3
    26,722
    I was just about to say its the fuse as Mattandrew & few others had same fault with econ staying on, but beaten to the post.
