Badger5Chris Nott
    Jul 2008
    Copenhagen, Denmark
    34
    Engine changes on the facelifted A3?
    When I look on the specs of the new models on the Danish Audi site, it comes to my attention that the 0-100 km/h acceleration (0-62 Mph in U.K.) is lower than before.
    For example:
    Sportback 1.8 TFSI 6-speed is now 7,8 seconds at 0-100 km/h (7,8 at 0-62 Mph) which was 8,2 seconds before.
    Sportback 1.8 TFSI S-tronic is 7,8 seconds at 0-100 km/h (7,7 at 0-62 Mph - it says so on www.audi.co.uk). It was 8,0 seconds before, so the manual gear is prette much just as fast now?
    3-door 1.8 TFSI 6-speed is now 7,6 seconds at 0-100 km/h, which was 8,0 seconds before.
    3-door 1.8 TFSI S-tronic is 7,8 seconds which was the same before.
    So have they upgraded the engines, lowered the weight, change the gear boxes or?
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    I know they have revised alot of the software on the engine ecu to make them more efficient and this may be the case....
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    Jul 2008
    Copenhagen, Denmark
    34
    I see. Thanks for clarifying .
    Stalled
    Feb 2008
    249
    The main reason for the lowered sprint time is because of new aerodynamics, the new A3 now has a flat underbody meaning less drag is created allowing for the quicker 0-62 time.
