Removing Chewing Gum
GlasgowRangers
UK
Have just returned home after a trip to Ankara and discovered chewing gum above my rear wheel arch. The weather is hot so it's all sticky. Any ideas how to remove this crap from the car? Wanted advice before I attempt to remove it.
I'd probably go down the old route of putting an ice pack on it then picking it off. If you've recently had the car waxed (think i saw your post recently about having your car fully detailed?), the gum shouldn't stick if it's cold.
if the ice cubes can't stand the heat, use your fire extinguisher. Should freeze it instantly...lol
anyway, you can also spray WD-40...some people suggest this
use an old credit card to scrape it off.
12
707
865
883
18K
Deleted member 21388
D
647
