Volks AutosEM Tuning
Page 6 of 8 FirstFirst 12345678 LastLast
Results 201 to 240 of 315
Like Tree3Likes
Thread: Coming Home & Leaving Home Lights Enabled
  1. #201
    Silky-S3's Avatar
    Is loving his new 8V S3!
    Jan 2009
    1,389
    Finally got round to doing this today, works like a treat! I just used some old house wiring cable I had, earthed it and then just pulled it out in the connector. Jobs a good un...
    Just to note, when I plugged my light switch back in (when refitting the trim) it turned the CH/LH lights off, I had to earth it with the light switch connected to get them to stay working.
    Matt
    S3 8V Sportback Stronic, Estoril Blue Crystal Effect, Black Interior, Adaptive Cruise with Stop & Go & Pre Sense, Super Sports Seats with Electric Lumber, LED Headlights, Interior Lighting Pack, Hill Hold Assist, Privacy Glass, Comfort Package, Technology Package with Audi Connect, Advance Key, Folding Door Mirrors, Extended Mono.Pur Interior, Front and Rear Parking Sensors, Audi Sound System.
    Build Thread Here!
  3. #202
    Mar 2008
    126
    Hello all, I've gone through the thread and become slightly confused. However, from what I gather my vehicle, 2005 SB, no interior light pack or rain / light sensor pack should work fine with the wire mod described and VAG coding? Do I need to disconnect the battery to do this mod?
    Rob
    A3 8P Sportback - 3.2 Quattro - DSG - S Line - Leather - RNSe - Bose - Heated Seats - Rear Parking Aid - Cruise - ILP - Moro Pearl Blue
  4. #203
    27,083
    No as it needs a signal to tell modules the wire has been connected.
  5. #204
    Mar 2008
    126
    Thanks for that. I'm going to have a go at it tomorrow along with fitting my cruise control stalk.
    Regards
    Rob
  6. #205
    Mar 2008
    126
    H, all, just in the middle of this mod, but its just occurred to me, how can I tell which pin 12 is? Is there method for counting down etc?
    Rob
  7. #206
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    Quote Originally Posted by Relaxitscool View Post
    Rob
    http://sites.google.com/site/audiret...minghomelights
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
  8. #207
    Mar 2008
    126
    Sorted!! Thanks!
    Rob
  9. #208
    27,083
    For reference the pin numbers are marked on the connectors anyway.
  10. #209
    Mar 2008
    126
    My mistake was assuming the plug was the connector. It wasn't until Matt pointed out that the connector needs to be removed from the plug that I saw the numbered pins. An easy mod, and if I can do it, anybody can!
    Regard
    Rob
  11. #210
    Lewbo's Avatar
    Aug 2009
    Hull
    1,045
    this is a really cool feature and would like to have a go at this myself but what vagcom system would i need to enable this feature can it be bought on ebay ect and what price looking at?
    all help appreciated thanks.
  12. #211
    Khufu's Avatar
    West coast of Scotland
    5,693
    Quote Originally Posted by a3_sline_tdi View Post
    try looking here:
    http://www.audi-sport.net/vb/forumdi...VAG-COM)-forum
    The cheap ebay ones are restricted & cant do things the official cable/software can.
  13. #212
    gynads's Avatar
    Oct 2009
    338
    anyone in NE Lincs with VAGCOM to help me do this please?
  14. #213
    27,083
    Try the link in my sig.
  15. #214
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    I've tried to do this install today....But everytime I connect the earth wire to the point it works.....and then I tried it tonite again and no lights came on at all when I pressed the remote key to unlock the doors. I all so did a vag com scan and it came up with this:
    Address 09: Cent. Elect.
    Control Module Part Number: 8P0 907 279 A
    Component and/or Version: Bordnetz-SG 1.0 H27 0401
    Software Coding: A18C4F00A0141000000000000000000000
    Work Shop Code: WSC 00000
    Additional Info: 8P2955119 Wischer WWS Audi350 0130
    2 Faults Found
    00216 - Signal EC-mirror Fade Out
    009 - Open or Short to Ground
    02104 - Light Detection Sensor (G399)
    010 - Open or Short to Plus
    Can any one help me on this one? ........
  16. #215
    heyadamhey's Avatar
    May 2009
    Joburg, South Africa
    126
    I set this up and could only get the leaving home lights working - intermittently.
    Are there any requirements for it to work as described?
    Akoya TDI 140, 18" S4 Rims, VCDS, H&R
    Getting Hybrid treatment
  17. #216
    Digzz's Avatar
    Jan 2009
    London
    1,383
    I'm also only getting the leaving lights to come on......and it only works sometimes...it's like it has a mind of it's own. is anybody else having these problems?
  18. #217
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Any Body got answers to my Vag-Com Test and why it only works sometimes?
    2 Faults Found
  19. #218
    27,083
    Those errors are because the CH/LH actually relies on the light sensor thats also built into the rear view mirror, hence no mirror with sensor, errors will show.
  20. #219
    Digzz's Avatar
    Jan 2009
    London
    1,383
    It can't be ...because I don't have the rear view mirror which auto dimms.....I have a 53 plate.
  21. #220
    27,083
    Read the post again mate, you just said what I said & explains the errors, you get the errors cause it doesnt see the mirror installed which these features rely on anyway.
  22. #221
    Digzz's Avatar
    Jan 2009
    London
    1,383
    But it states in the "audiretrofit" site that. quote: "It is not necessary that your car have auto-lights\wipers or auto-dimming mirrors to enable this feature". So can't understand why it don't work and why i'm getting these errors.
  23. #222
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,425
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    I think what NHN is trying to say buddy, is that it will still work regardless of the light sensor being installed (which is what it says on the retrofit guide). It will still look for the module and not be able to find it but it will still work.
    If you dont like the error, put it back to standard and not have the WH/CH function.
    If you look at some of the older cars that have this feature it doesnt activate during the day but does at night. This is the job of the light sensor. The retrofit guide just makes it work all the time as the car cannot distinguish between night or day
  24. #223
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Quote Originally Posted by Cruiser89 View Post
    I see what your saying now.....The only problem now is that it only works sometimes. Do you think it's due to the light sensor? and if so will installing this light sensor fix this problem?
  25. #224
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Are there any other people getting the same thing as it only works sometimes ?
  26. #225
    heyadamhey's Avatar
    May 2009
    126
    mine seems to work even less often now. when I get round to it, I want to re-check the wiring - see if it's not a loose connection causing it to be intermittent...
  27. #226
    27,083
    Hoorah finally someone got it, lol, yes a sensor fit would fix this as it would have the sensor to work via, thats the whole point, the system uses the sensor to tell the car when to turn the lights on/off, when you enable the feature it looks for the said sensor & associated parts that should be fitted on the car, because it cant see them fitted on the car network it is advising you with no communication errors with these parts, you will get these errors until you fit the proper ch/lh required parts.
  28. #227
    Digzz's Avatar
    Jan 2009
    London
    1,383
    It still doesn't answer my question to why it only works in only sometimes...or hardly ever.....
  29. #228
    27,083
    Geeees, I dont mean to be funny, but think about it a little bit more & then you'll realise what I do, you're basically enabling a function on the car that isnt meant to actually work without other things fitted, so its entirely possible you will have issues, I've heard it before from others & I gave them the same answer, fit the oem parts then you wont have any issues at all, also from your sig pic it could be because you have an older 8P & the central electrics board A doesnt like the fact the sensor etc arent fitted, did you check the wire at all again, did you try enabling/disabling/connecting wire/disconnecting wire, all things to be checked.
    Also your central electrics board is a basic iirc so this may also affect the workings, it is superdeded as far as a D, where as the high end is superseded by several others with higher functions, check with Adam what board he has as you both seem to have similar issues.
  30. #229
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Thanks for your help mate....I think I'm going to wait to get my S6 LED'S fitted to sort out everything......
  31. #230
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Has Anybody Installed this Device For the Coming Home & Leaving Home Lights?
    It seems to be a device with a light sensor
    http://cgi.ebay.de/ws/eBayISAPI.dll?...X:eRTM:DE:1123
    I've already asked the guy and he states it will work on the Audi A3 8p .
  32. #231
    27,083
    Yes I've seen this & I would be weary, but if he can email you a manual (english one) then we can check wiring to see if possible.
  33. #232
    Digzz's Avatar
    Jan 2009
    London
    1,383
    I've got the manual but only in German.
  34. #233
    27,083
  35. #234
    Digzz's Avatar
    Jan 2009
    London
    1,383
    This is the manual ..
  36. #235
    evapor8's Avatar
    Jan 2009
    Guernsey, Channel Islands
    463
    This may/may not already be mentioned in this thread, but I thought I'd add my experience on the coming home and leaving home lights.
    Whilst doing some other bits, Gareth from Hazzy Days coded this for me.
    However, as I don't have auto lights, this coding meant that my main beam lights were on whenever my DRL's were active .... so I had him switch it off again.
    A bit disappointing for me, but I don't want my main beam on all the time!
    Chris
    Car: Phantom Black A3 2.0 TFSI S-Line BLACK EDITION, 3-door, manual
  37. #236
    audiv6's Avatar
    Mar 2010
    53
    ok ive just got my repair wire from vw as its handy to me but it has a round pin like connection at the end?? is this wrong should it be like the square type??
  38. #237
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    It should be square yes
    8P2 S3
  39. #238
    audiv6's Avatar
    Mar 2010
    53
    cheers mate il get it changed 2moro!
  40. #239
    waring192's Avatar
    Dec 2009
    North West
    390
    I have a similar problem, when DRL's are on the headlights are on also? I can also go from dip to main while in that mode. Is there anyway too stop this without getting rid of the mod?
    S3 Sportback - Ibis White
    Factory: Privacy Glass, Cruise Control, Heated Seats, RNS-E, Bluetooth, Bose, Ipod Dock
    Modifications: Revo Stage 2+, Forge CAI, APR HPFP, Milltek TBE - H&R ARB's & Springs - TV Tuner, Reverse Camera
    Wanted: Stock S3 facelift alloys
  41. #240
    Apr 2009
    70
    Hi All,
    Am I right in thinking that all I need to do is make a code change in vag com for this? I have a 59 plate A3.
    If so, anyone here kind enough with VDS to assist? I'm in the Shropshire area. Cheers
    A3 Black Edition - 3dr, 2.0ltr TDi 170, Phantom Black, DRL's, FBMFSW, BOSE, Symphony, Interor Light Pack, Folding Mirrors, Rear Parking Sensors, GSM Phone Prep, Flat Tyre Warning and Alu Inlays
