JMB RetrofitsSky Insurance
Results 1 to 15 of 15
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    About to start the retrofitting of the interior light pack......but.......
    i could do with the part number of the 'repair wire' which people use to connect to the electrical block under the steering column.
    I have bought all the lights etc to do the work so i just need the wire, i was hoping to be able to find something at work to do the job but failed...............
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Is this an easy job to do? Do you perhaps have a DIY as well as part numbers for the interior light pack?
    2012 RS3 / Daytona Grey / Alu pack / revo3+ / LOBA500P / LOBA CNC Intake pipe / LOBA HPFP / Forge Race FMIC / Milltek resonated exhaust / revo intake system / Devils own WMI / 20" BBS CH-R Titanium / H&R Monotube coilovers / H&R Anti Roll bars / Alu Roof rails / Hybrid RS grille / R8 paddle shifters /
    2008 Audi S3
    Oct 2007
    South Africa
    197
    Quote Originally Posted by Rabbit222 View Post
    It's basically putting a light in each footwell in the 2-door cars, it's easy to put in. You can also replace the roof light unit (plug and play) to give some additional lights.
    The additional lights package is a bit harder to do (puddle lights, lights in doors, etc).
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Quote Originally Posted by sakkie69 View Post
    I'm keen on that You have any part numbers and a DIY?
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Quote Originally Posted by RobinA3 View Post
    I've just retrofitted the Aux in connection to my RNS-E and used the the following part number for the repair wire (thanks to MarcQ)
    000 979 009
    Should be about 1 from your local dealer.
    Jon
    Now A3 less......
    Dec 2006
    Ireland
    2,538
    There are numerous repair wires of all shapes and sizes.
    Here's the DIY for the footwell lighting: http://forums.fourtitude.com/zeropos...how&id=2536694
    looks like you need 2 of 000 979 133 and one of 000 979 131.
    There is also a hole under the front seats to install lights under them. All part numbers are in the DIY guide.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    I'll be retrofitting the following this weekend
    Puddle Lights (underneath the door cards)
    Foot well lights
    Red Warning light (end of the door card)
    I'll do a DIY thing on it whilst i am doing it so i will post it on here.
    I have some spare lights (white footwell and puddle lights) which i got from Audi so if anyone wants any then let me know or else i'll put them on ebay. They were 7ish from Audi.
    2008 Audi S3
    Oct 2007
    South Africa
    197
    You got part numbers for the puddle lights? Or are they same as the footlights?
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    they are the same as the footwell lights
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Does anyone know if i can feed all 6 lights from the single pin coming from that electrical block?
    Dec 2006
    Ireland
    2,538
    That's what it seems to be suggesting.
    Did you read the bit where it said you should use some sort of shielded housing for under the seats to prevent them from catching fire? It recommends using boot light housing for under the seats.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    I have got the wiring diagram for the interior lighting pack and the door puddle lights and warning lights run off a different pin, they don't all feed from one single pin. I think i'll do it properly and feed them off the correct pins rather than just one.
    Yeah i read about the sheild, i have got myself some lights which have a backing plate on them.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Right after a bit of investigation the whole job seems quite straight forward.
    If i were to get 'kits' made up for this modification would anyone be interested? The 'kit' will contain the following:
    Instructions
    All the lights (puddle, footwell, red warning)
    All the wiring cut to the correct lengths including the plugs to the electrical block and lights.
    so basically it would be a pretty much plug and play (having removed interior trim etc) apart from having the function turned on via vag-com.
    Scorpius's Avatar
    The S Factor
    Apr 2008
    South Africa
    82
    Looks a rather interesting mod. Anyone have a pic of an A3/S3 with puddle lights? Most cars I know have them on the side mirrors but it seems the A3/S3 has them on the doors. Would love to see what this looks like
    2008 Audi S3
    Oct 2007
    South Africa
    197
    Just imagine lights in the door, at the bottom of the black plastic.
