A3 cabriolet rear lights - Picture request
mattandrew
Up in the hills, Derbyshire
I am in the process of fitting N8KOW's S3 Sportback new rear lights to his 2008 SB but trying to work out the wiring as they now incorporate a LED ring similar to the new cabriolet.
What I am looking for is pics of the cabriolet lights with there different lights on, they hopefully will be similar to the SB lights
Pictures required
1. Lights off
2. Side light on
3. Brake lights on
4. Side and brake on
5. Fog on
I have got the led rings to work but not sure what else they work with.
Also if anyone with a cabriolet in the Derbyshire or Cheshire has one Nathan or myself could have a look for ourselves if convenient.
Thanks in advance
i'll see if i can get a some good pictures of mine up later for you
oempl.us are advertising an upgrade to the new european taillights.
http://oempl.us/index.php?main_page=product_info&cPath=60_61&products_id=754
Bit pricey since they come in at about €200 all in over here - although it does come with a wiring harness. Would it be worth firing them off an email to see what the wiring harness consists of? My guess is that it is just a male and female connector that sits between the existing loom and the lights.
European Taillights - LED Upgrade
$745.00
If you would like to update your A3 to the European 2009 LED specification, this is the OEM way to go. Includes all lamps and wiring harnesses for retrofit.
Model: 8P4945095E
Units in Stock: 0
Manufactured by: Hella
They're actually Matt's own photos!!
Probably not much use to him then! :lmfao:
I didn't look who posted the pics on the thread...just knew I'd seen some night shots of the lights....and very nice they are too.
Anyway, apologies.......
Dave.
1. Lights off
2. Side light on
3. Brake lights on
5. Fog on
all lights off
side lights on
brake lights on
fog light on
reverse light on
hope these help?? sorry didn't take one of the brake light and side lights at the same time, but i've just checked and the sidelight stays on the same brightness with brake light on or off.
mat
410
813
993
