Badger5AH Fabrications
Results 1 to 8 of 8
    Jul 2008
    Copenhagen, Denmark
    34
    Camber on Sportback 1.8 TFSI
    Hi,
    I am new around here and hail from Copenhagen, Denmark. Happy to be a member in here as I have been browsing around, and it seems there are some competent people in here.
    I have a black Sportback 1.8 TFSI with an H&R Streetstyle stainless steel coilover plus some BBS CH "Black Edition" 18" ET50 alloys. I had it adjusted yesterday, and they told me the camber cannot be adjusted on the back - it is currently at negative 2,18 degrees on the left and negative 2,06 degrees on the right. Can that be true?
    I was hoping to fit some 15 mm H&R spacers on the back, but I reckon it will look silly with the negative camber .
    Peace,
    Jimmi
    Khufu's Avatar
    West coast of Scotland
    5,693
    how much has the coilovers lowered the car? If you have lowered it a lot the camber will point inward and it could scrum the inside of the tyres away quicker.
    Some companies brought out adjustable bars for the older S3 to correct this. like these :
    http://www.forgemotorsport.co.uk/con...product=FMAUTB
    Not sure if they are available for the newer a3/s3
    Jul 2008
    Copenhagen, Denmark
    34
    I think it's been lowered roughly 40-50 mm in the rear. It's hard to say really. According to the specs, this coilover should lower the rear from 30-60 mm and the front from 40-70 mm.
    S3IZZO
    Camber is adjustable on the back...it's just not on the front
    Jul 2008
    Copenhagen, Denmark
    34
    I've just talked to them, and the camber cannot be adjusted because the car is too low. So it cannot be adjusted that far - if I had the original springs/shock absorbers mounted it could be done. Too bad.
    S3IZZO
    http://www.k-mac.com.au/
    They do adjustable plates, I'm not quite sure what you are trying to do? - are you trying to gain some positive camber?
    Jul 2008
    Copenhagen, Denmark
    34
    Quote Originally Posted by S3IZZO View Post
    Yes, I just want the camber to be "evened out" on both sides. As I wrote, it is about negative 2 degrees on both sides, so the wheel is leaning inwards. And preferably I suppose it should be 0 degrees.
    S3IZZO
    Quote Originally Posted by JiSi View Post
    I don't think it should be 0, I think it would have a bit of negative offset even from factory...not as much granted.
    Could be worse
