Sky InsuranceChris Nott
Results 1 to 11 of 11
    Apr 2008
    98
    RNS-E with amp / JL Clean sweep ?
    Thinking of ripping BOSE out and fitting a aftermarket system.
    Has anyone fitted aftermarket amps etc with the RNS-E using line to RCA adaptors ? What it the sound like ?
    Has anyone used the new JL clean sweep to connect the amp etc ?
    (JL clean sweep is device which creates clean signal from factory headunit, only down side is you have to use a remote volume control)
    Is the sound any better with JL clean sweep ?
    Many thanks in advance
    mdre83's Avatar
    Aug 2007
    South East
    629
    Hi Whiteatom,
    Unfortunately I don't know the answers to your questions, but I do have a question for you...
    The wiring on the NON bose sound system, do you know whether it's the same for the BOSE, or would the whole wiring have to be changed if you were to retro fit the BOSE?
    A3 8P2 2.0TDI S-Line 170 SB | Brilliant Red | Full Leather | BOSE | 6 Disc Changer | None Smoking Pack | Light Interior Pack (Converted to LEDs) | Rear Parking Sensors | S3 Air Vents | S3 Mirrors - Stolen!| S3 Pedals |
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    doesn't the clean sweep just give a flat EQ, you could achieve something similar with alpines audio hub pro and it gives you much more options. I'm going down the road of new fronts, sub and 5 channel amp running active with the standard HU initially, if I do decide to change the HU then I would go aftermarket, look at the Alpine W502 and the Pioneer BT900
    try www.caraudiodirect.com
    Gone A3 TDi S Line DSG Bluefined
    Now Seat Leon Cupra about to be Bluefined
    mdre83's Avatar
    Aug 2007
    South East
    629
    I used to have the DEH-P9800BT in my old A3, cracking piece of kit
    Apr 2008
    98
    As far as I am aware the wiring is different with the BOSE system as with BOSE all the speaker run off the amp thus all the wires go to the back of the car. On none BOSE cars only the rear speakers and sub (not 100% it is rears) run off the amp. The other speakers run off the headunit.
    As for retro fitting BOSE, I would not bother. BOSE is better than standard system but aftermarket equipment with give miles better sounds for less money.
    Has anyone used the apline unit ? Any good ?
    Thanks for the replies
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    The wiring is different for a Bose install. Bose has a small amp behind the O/S panel in the boot, and I mean small - there are some pics of it in the thread I did in the ICE section of my build.
    To be honest unless you really want an OEM solution, the Bose route is a pointless upgrade (if you could do it). I would go aftermarket and if you have to keep an oem HU then either use an Line Out Adapter or Line Level convertors.
    Personally I ripped the lot out and went for an Alpine / Focal / JBL / IPOD solution.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    27,113
    Andymac is the man on here to ask, he'll be along any minute now as he always is or send him a PM.
    mdre83's Avatar
    Aug 2007
    South East
    629
    You got the link to your thread mate?
    Quote Originally Posted by Gti Jazz Blue View Post
    Paul
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by mdre83 View Post
    2005 A3 (8P) Install (3 door) 56K picture warning
    Feb 2007
    Hampshire
    1,654
    I still haven't got round to tidying up the amp rack in the boot, you can't see it though so out of sight out of mind.
    I will book a long weekend and sort it soon, got to do some maintenance work on our garage first.
    I've also got the controller for the processor, which is going to be installed out of sight in the arm rest.
    Paul
    VCDS HEX-USB+CAN
    Living a little!
    London
    181
    Any update on this OP? I have the RNSE with Bose and was looking at going this route with the JL cleansweep and JL speakers and sub after getting a demo from JL in an A3 and it was intense!
