Monster MotorsportBadger5
Thread: Air con smells
    Sep 2005
    Hertfordshire
    99
    Air con smells
    My air con has started to smell. Not really bad (though still not especially pleasant) - like pollen, or as though you're walking through a field of oilseed rape. Then it disappears after a few minutes, but may come back later. I'm not sure, but I think it also happens when the ECO button is on. Is it likely to be the obvious problem, i.e. the pollen filter needs changing, or could it be something else? Thanks.
    Sep 2005
    Hertfordshire
    99
    Sorry - just realised I should have done a search first... There's a bit on there about smelly air con, but nothing specific about pollen smell.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I think your first guess maybe spot on mate. Not sure where the filters are though tbh.
    Incidentally there is now an air con forum on this site. Eventually I hope people will use it lots and learn from it and then can answer questions for others.
    8P2 S3
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    This is known of air con. Its a build up of bacteria (yuk!) due to the cooling then damp conditions of the condenser.
    You can buy cleaner (i think comma make it) that you spray over the intake under the fresh air duct after removing the pollen filter.
    If you can be bothered to do this, you can run the car for 20 mins with the heater on full blast and the condenser off(max heat on econ).
    http://www.commaoil.com/product%20Pa...irconclean.htm
    Porsche 997 Carrera 4 S - Black, Sport Chrono, Sport seats, PCM, Nav, Tel, Park assist and rear wiper (Yes!, its an option!)
    2012 Audi Q7 Sline Plus - Daytona Grey ,Nav+, Wheel upgrade, Storage and tow pack.
    Gone -2007 S5 4.2 ,2008 S3, 2007 TTC 3.2, 2007 RS4 Saloon, 2004 S4 Saloon, 2006 A4 2.0T Sline SE,2002 A3 3.2 Sline, 2001 A4 1.8T,2001 Boxster, 1983 911SC,1992 Corrado G60,1988 GTi.
    (Vag com owner)
    Boydie
    The pollen filter is located behind the glovebox - it is easily accessed and is literally a 5min job!
    I took mine out not so long ago and it was black!!!
    Aircon still smells though when it is not on so going to bug bomb it soon!
    Sep 2005
    Hertfordshire
    99
    I tried the stuff you mentioned The911SC, but the smell returned a couple of days later. The next step I'll take is to change the pollen filter. Anyone know where I can get one at a reasonable price and how to change it? Thanks.
