Badger5Monster Motorsport
Results 1 to 27 of 27
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Yet another problem with auto-windows
    I have now had the problem a few times where on auto close the window would then drop down a few inches as if there is something trapped inside the seal. The end result each time was I had to reset it and then all would be ok.
    After that problem went I found sometimes that after the window had raised fully I could hear a clicking coming from the motor area as if it was trying to push the window fully up but something was stopping it. Only once in the last month has the window lowered on it's own though.
    Today I drove my car and fully auto opened the window. I drove 2 miles and then when I pressed to close the auto feature had gone so I had to reset again.
    I plan to pay a visit to Bedford Audi when I'm in the UK next month (I tried Audi here but there is a bit of a language barrier and the tech I saw didn't really know what to do) but I wondered if anyone else had similar problems and how they got it sorted in the end.
    Thanks in advance
    Staz
    8P2 S3
    27,096
    Its one of 2-3 things, door switch pack as that uses resistance on 4 wires to tell the door module what feature to operate like different windows, mirrors etc, could be fault with circuit on the switch pack pcb maybe faulty resistor, door module does everything on that door so could be that & the clicking noise is the relay inside the door module & if this is being heard after closed then seems to point to that & lastly & most unlikely is a wiring issue, but as the windows lower & raise its doubtful, I am leaning towards the door control module given my experience with mine & the clicking after closure/lowering, it only usually clicks when the auto closure/lowering is activated which is done by holding the window button for 2-3 seconds then it powers the relay to hold power on that function.
    27,096
    Didnt we have this discussion already about your windows or someone else?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by nigelhobden View Post
    Someone else posted about theirs recently (I replied to it) and there have been a few over the years.
    I'm posting now because the fault is still ongoing and keeps changing its symptoms. In fact I have just remembered, I dropped my girlfriend off last night and she left her window a few inches open and I found that it had forgotten the auto close on that side too (from my switch). Just to make thinks a bit more confusing hey?!
    I have had no reports that the auto close hasn't worked on 'her' side though.
    8P2 S3
    daviscup's Avatar
    Jun 2007
    Northern Ireland
    132
    I had the same problem mate. Took it to the dealers about 3 weeks ago and they did a software update for the windows. No problems since
    "Why So Serious?"
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by daviscup View Post
    Fingers crossed they can do the same for me!! Cheers!
    8P2 S3
    Kontraband's Avatar
    Dec 2007
    1,998
    yeah, I posted about it recently too... its into the dealers tomorrow...
    27,096
    Aha I thought it was one of you lot that also posted this & i replied, lol, its interesting theres software or we should say firmware updates for the door modules huh, sounds like a problem with relay interaction to me as people are reporting clicking with problem, be good to know if yours all get resolved by software update.
    Kontraband's Avatar
    Dec 2007
    1,998
    yeah, they have had to order a door control unit for mine. No firmware fix. So its back to the shop next week.
    27,096
    (As I try hard to get my head through the door) lol, I did say it was the module for both of yer boys, on a serious note the clicking could only be one thing in the door & thats the module as thats the one part that has relays inside it, I've stripped my door down that many times I know it fairly well.
    Kontraband's Avatar
    Dec 2007
    1,998
    is the module only in the drivers door??
    27,096
    well you have one in each door & when you do the mirrors/windows drivers door for passenger I believe it just uses CAN signal to lower, move etc, I cant imagine it wires from left to right as whole point of DBW/CAN etc is to lower cabling, reliability, easier fault finding & faster signalling overall, I havnt traced wiring from door to door(YET in caps, lol)
    door module also is part of the window motors, does unclip but I didnt need to go that far, the drivers door switch pack uses a clever system of resistance to lower voltages etc to signal the door module to do something, this cuts down on wiring dramatically, very impressive & stupidly simple, so you can use 3-4 wires to do 10+ wires job by putting resistors inline with different positions of the mirrors & folding, took me while to figure that one out which required dismantling the door switch pack, mirror dial etc to trace the pcb so gave me understanding of the wiring/closure circuits
    But to throw spanner in works, the dimming part of the side mirrors isnt CAN at all, its purely wired straight from the rear view so on one side you think ok they wouldnt do that amount of wiring then thats disproves the theory to a degree, kinda stupid IMHO
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Just a quick update. I found yesterday that the passenger window dropped down after I auto closed it from my side. I now realise that the other day when I dropped my misus off she hadn't left it open, it had dropped down after she had closed it from her side.
    So it's both windows from both switches. Sounds like the control module to me.
    8P2 S3
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    An update now TrickyLad has reminded me:
    I had the software on my electric windows updated about 4 weeks ago and 2000 miles later and I haven't had one single occurance of the windows forgetting the auto function or of them opening back up 2 inches.
    I have had the clicking thing a few times so I intend to go back to get that looked at. One time I left it clicking to see how many times it would do it but at 30 I decided to give up waiting.
    8P2 S3
    is loving his new A3
    Mar 2008
    North West
    118
    mine is going in the garage for an oil change and tyre check up in a few days so i am def going to mention this to them
    problem i have is sometimes it works fine and sods law is when i give it them it will work fine and they wont do anything about it.
    Oct 06 - Feb 08 VW Polo '06
    Feb 08 - ? A3 1.6 Special Edition '07
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by TrickyLad View Post
    Mine wasn't doing it at the time but it didn't matter. They know of the fault as it has been reported by Audi that a software update is required.
    8P2 S3
    Mar 2008
    North West
    118
    quick update
    apprently blackburn garage know nothing about this so called fault and made me feel like i was a liar when i said its a problem i know others have had.
    anyway its in on saturday, apparently no cars i can have for 2 weeks so i get to sit around in showroom for an unspecified amount of time
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    quick update
    I'd either call Audi customer service or call another garage to confirm that they have heard of it (try Bedford as that's where I went) then kick off.
    When I go into a dealership I never let them fob me off with a ******** answer.
    Either the person you spoke him/herself didn't know or they're just mongs.
    8P2 S3
    27,096
    Leon, can you let me know what the drivers door module version is/software version & the coding for both doors please mate as I have updated my drivers to the new J version & have now got the window dropping problem, fixed the bloody folding issue on drivers but now when I use full closure system & then come back next time I unlock the drivers drops down slightly, there is a label file issue me & Stu have found for newer modules which hopefully sebastian will look at from ross-tech, but any info would be appreciated fella.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    How do I find the door module info mate?
    8P2 S3
    27,096
    drivers door is 42 & passengers is 52 in vagcom, go into select module & at bottom put in 42 or 52, the coding & part number is at the top as with all, just curious to know what yours shows fella please.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I've never taken much notice of that lot of info at the top!
    Ok driver's door:
    VAG Number: 8P0 959 801 K
    Software coding: 0000632
    Passenger:
    VAG Number: 8P0 959 802 K
    I have interior light pack but not auto dimming mirrors. Anything else mate?
    8P2 S3
    27,096
    whats the hw & & sw versions on the drivers fella?
    no msn today?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Ok here you are mate:
    Tuer-SG H03 0060
    8P2 S3
    royjk's Avatar
    Apr 2008
    167
    Just had mine sorted on the Cabrio, rear windows, new controlers fitted seems to have solved the problem
    A3 CABRIO S-Line 2.0 TDI DSG
    Liquid Blue-Blue Hood. Celtic Tunning Remap with E Motion -RNSE-Seperate DVD Player-100gb Portable Hard Drive-USB-Phone Prep-Exnon Adaptive Lights-Heated Seats-Lumber Support-Acoustic Parking-Light & Rain Sensors-Interior Light Pack-Storage Pack-Cruise Control-Folding Dipping Mirrors-Interior Auto Dipping Mirror-Bose-Hill Hold-SDS-FBMFSW - Alpine iPod Controller
    27,096
    Ye but what was your problem?
  28. #27
    royjk's Avatar
    Apr 2008
    167
    When you lowered or closed the hood either one or both windows would not close automaticaly.
