Chris NottMonster Motorsport
Results 1 to 10 of 10
    ADEY's Avatar
    Feb 2008
    Skegby - Notts
    242
    HEATED SIDE MIRRORS...How do you.....
    .....know if they are working?
    When i push the button (on the drivers door ) towards the 'heated mirror' symbol it springs back to the central position
    is this correct? or does my model (2.0tdi 140 55plate) have this function?
    or am i being a total arsehole who doesn't know how to operate this?
    Would look in the manual but unable to find it at the moment
    A3 2.O TDI 170 S-LINE
    dsl55's Avatar
    exploring other avenues
    Mar 2008
    254
    not sure dude, my 08 model has 3 positions, 2 for moving the relevant mirror and the third, which i leave it in, for heated, doesn't spring back anywhere
    2008 pre facelift 2.0 TDi 140 S-Line A3 Ibis
    2008 new model 2.0 TDi 140 SE A4 Quartz Grey for family wheels
    '60's bug in the pipeline!!
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,721
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    ADEY's Avatar
    Feb 2008
    Skegby - Notts
    242
    Thanks dsl 55 - yeah mine has the same 3 positions so do we assume they are on all the time?
    just wondered with the weather being ****e today the mirrors had condensation on them and thought his function would clear them
    Neil C's Avatar
    May 2007
    Grantham
    75
    Mine's like that too.
    Seem to remember reading somewhere (not sure if it was in the manual) that the car decides when & how long to heat the mirrors for. I suppose it senses things like outside temperature, whether the wipers are or or not, etc.
    2004 (54) A3 Sportback TDi Sport Liquid Blue
    Dec 2006
    Ireland
    2,538
    Do you mean that when you push it forward to turn on the heated mirrors manually that it returns to the original position? If so then this is normal. It doesn't stick in the forward position until you turn them off. The car turns them off itself when it thinks they have defrosted.
    ADEY's Avatar
    Feb 2008
    Skegby - Notts
    242
    [quote=MarcQuinlivan;563966]Do you mean that when you push it forward to turn on the heated mirrors manually that it returns to the original position? If so then this is normal. It doesn't stick in the forward position until you turn them off. The car turns them off itself when it thinks they have defrosted.[/quote]
    Yeah - thanks for that
    ADEY's Avatar
    Feb 2008
    Skegby - Notts
    242
    Quote Originally Posted by Neil C View Post
    thanks for that Neil
    Aug 2004
    Bolton
    119
    AFAIK, The heated mirrors come on automatically depending on the outside temperature (can't remember what it is).
    They also come on when the heated rear screen is switched on.
    This only happens when the mirror control button is in the central position, pushing it towards the heated mirror symbol does nothing.
    Ian
    Now: A3 Sportback 2.0TDi Sport, Akoya silver, black alcantara/leather, Bose.
    Gone: A3 2.0TDi Sport, Lava Grey
    A3 (8L) 1.9TDi Sport, Silver
    Dec 2006
    Ireland
    2,538
    5 degrees or lower (i.e. when the frost symbol is on the DIS), however you can manually activate it by turning the dial to the centre position and pushing it forward. Says so in the manual.
    It is possible that the exterior temperature can be above 5 degrees but your mirrors are still frosted up which is the reason for the manual control option.
