Volks AutosMonster Motorsport
    Jun 2008
    A3 2L FSI Oil Pressure Warning Light
    Hi,
    I purchased A3 FSI Sportsback 2L and I want to see if anyone else had any issues with the 'Oil Pressure' warning lights? Car is 2005 model with approx 20000 miles on the odometer. The first time oil pressure warning light lit was about a month ago and I took it to Audi service where they claimed to fix the problem. 1 month later oil pressure warning light came back. I checked for oil level using the dipstick and it has oil in the engine. I don't drive the car often and the interesting thing I noticed is that the light comes on when the car is really low on fuel. Both times that the light lit was when I was low on fuel. Anyone had similar issues? can anyone suggest what's wrong here and should I worry?
    Thanks guys...
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    i would find someone local with VAGCOM and ask them to do a scan for you to see if any fault codes have been listed on the ECU, that would tell you what was causing the oil warning.
