Hey
After a couple of questions about my intake set up on the S3 I thought it was time I should post a couple of pics and thoughts on the item..
I bought my EvoMs intake from Regal Autosport who are based in Southampton, they are the official importer for EVOMS in the Uk, great bunch, very helpful and will be at GTI International this weekend (usually with goodies in stock, gets me every time)
Previously I had a Neuspeed Intake fitted to the S3, it follows a similar design but with no heatshield for either the intake pipe above the turbo nor the filter itself which would make it prone to heatsoak and ingesting hot air from the engine bay
The EVOMS intake is supplied with the filter heatshield and for an extra £25 is available with the heatshield above the turbo which I would recommend, every little helps..
I have found the intake to really free up the S3, especially once the car was re-mapped, and makes a fantastic noise too, spool and also a nice blow off noise from the DV
I have made a couple of extra modifications to the intake system by firstly adding a heat reflecting tape to the intake pipe work closest around the turbo area. I found this reduced the temp of the intake to the touch and also after sitting in traffic etc the car didn't seem to suffer with the same level of heatsoak
Also I bought parts to construct my own cold air feed, including a 100mm venturi duct and flexible ducting. I mounted this so it would pull air from low down in the passenger side fog light grille and feed it directly to the filter itself via the flexible ducting. Pleased with how this turned out and the venturi duct in the grille isn't too noticeable, I was a bit worried about it looking a bit chav!
Really pleased with how the intake is performing now and IMO certainly a worth while mod for the S3
Heres some pics of the finished intake..
Jonny
Jonny
