Monster MotorsportChris Nott
Results 1 to 22 of 22
    jonnyc's Avatar
    Jul 2007
    846
    Forge Motorsport DV for S3/ED30/Cupra
    Hey all
    Fitted my Forge Motorsport DV today, install was pretty straight forward following the instuctions in the box.
    I managed to package it in nicely using the EVOMS Intake heatshield as a good mounting place for the Solenoid..
    First impressions are great, car feels less hesitant in the mid range and pulls a little harder top end too, car idles great and zero problems with running over the last 50 miles that I just drove the car..
    The biggest improvement is the reduced spool time, both between gear changes and when jumping on the power in gear. This really makes the car much quicker to respond to throttle inputs and as a result improves acceleration..
    A really worth while modification for all S3's in my opinion, especially for those cars running with re-maps and any other engine modifications..
    Quick thanks to Peter Miles at Forge UK
    Heres some pictures of the valve installed on my car
    (apologies for the state of the engine bay, so hard to keep clean without the engine cover!)
    Jonny
    MK5 ED30.. Fastest MK5 / 2.0T FSI in the UK - Fastest DSG MK5 in the world!
    12.601 @ 115.85 MPH
    May 2008
    Switzerland
    108
    Nice job!
    I thought the DV came only in polished alu...
    S3 8P + Milltek non-resonated exhaust = Fuel-to-noise converter
    Jun 2008
    Luxembourg
    103
    Nice Do you get that "psssssssssshhhhh" noise with this one too?
    Is it needed to keep the engine cover off after the installation?
    How much was it?
    Tim
    May 2008
    Switzerland
    108
    Quote Originally Posted by Doublemint1984 View Post
    Nope, that's an improved recirculation valve. To make it a blow off you need the spacer...
    Nope, he removed the engine cover because of the direct air intake mod
    Jun 2008
    Luxembourg
    103
    Ah ok I see. So does it make a change to the sound at all?
    I read lots of mixed opinions about DVs. Some say it improves spool up etc, some took it off after a while, because there was no improvement at all.
    jonnyc's Avatar
    Jul 2007
    846
    Quote Originally Posted by Macs View Post
    Nice job!
    Its is, It was anodized black as a one off piece, im told its the only one of its kind..
    The noise is very slightly different to the OEM DV, the only reason you can hear it at all is because of the intake that I have fitted to my car.
    The difference in subtle, but for sure as the power and boost level increases so will the improvements of having the Forge valve over the OE piece..
    And yeah the reason for no engine cover is because of the EvoMs intake kit that I have fitted.
    Jonny
    12.601 @ 115.85 MPH
    aiculedtzu's Avatar
    under pressure
    Oct 2006
    Romania
    208
    I bought mine almost 1 year ago and never used it
    Thanks Jonnyc for the review, i will install it soon and of course i'll make a lot of logs with VAG COM to make sure everything is going well
    Audi S3 2.0 TFSI quattro - Turbo-Back exhaust - Cold Air Intake - Uprated Fuel Pump - Upgraded Clutch - Upgraded Intercooler - Stage2+ Software
    L60N
    Jonny are you racing this weekend?
    jonnyc's Avatar
    Jul 2007
    846
    Racing?
    12.601 @ 115.85 MPH
    jamiekip
    Sooooo how much was it mate?
    Vtec Abuser's Avatar
    Jul 2007
    Lincoln
    306
    Quote Originally Posted by L60N View Post
    He's running up the strip @ Inters if that's what you mean? (At least he was AFAIK)
    We have a score to settle with a RS4..
    L60N
    Quote Originally Posted by Vtec Abuser View Post
    Yeah thats what i meant
    Jonny wont be racing this year tho
    Are you still racing? I thought there was a yellow 991 (EssThree) that threw the gauntlet down
    jonnyc's Avatar
    Jul 2007
    846
    Hey
    Yea im still up for having a go against a couple of the cars that we mentioned in the other thread..
    Only problem is that I have just spent 1300 on a new Sachs racing clutch and flywheel which is working excellent at the moment, but im not keen on launching the car after seeing the state of the old parts.. As you would imagine the 4WD puts huge strain on them parts when launching the car!
    Going to have to see what they think to a 5mph roll or something like that..
    Jonny
    12.601 @ 115.85 MPH
    L60N
    Woohoo
    I cant wait for this sunday, just hoping for good weather!
    Jul 2007
    Lincoln
    306
    I reckon if you launch it lightly or start with a roll then boot it, you should be ok, as I will still be spinning my cock off if the other lane anyway.. Ha ha..
    L6ON, i've got 3 runs, so will run against whatever to be fair, really don't mind.. But a Porsche, RS4 and handicapped S3 would be nice.. lol
    Jul 2007
    Lincoln
    306
    http://www.bbc.co.uk/weather/5day.shtml?id=2477
    F**CKING GREAT!!! That 15 sheets down the $hitter! Hope everyone's bringing a brolly..
    jonnyc's Avatar
    Jul 2007
    846
    Lol we will sort something out im sure..
    12.601 @ 115.85 MPH
    S3IZZO
    Wetness, mmmm...should make the 1/4 even more interesting for the S3's
    L60N
    I never trust weather reports for anything over 2 days in front. I used to work in a job where weather was paramount to production and I lived my life by metcheck LoL.
    L60N
    Metcheck has given this for example:
    http://www.metcheck.com/V40/UK/FREE/...ngthorpe&day=4
    Dry all day up until 4pm. Its all subject to change though
    P.S. Metcheck is the bible when it comes to weather forecasts
    Jul 2007
    Lincoln
    306
    I soooo hope you're right mate. As really looking forward to sun, not just the strip, but the whole day..
    L60N
    We'll have to wait and see, the weather changes all teh bloody time!
    I'd love to have a race, but I suck balls when it comes to standing starts
    As can be demonstrated here
