Chris NottJMB Retrofits
Results 1 to 30 of 30
    Dec 2006
    Ireland
    2,538
    Thumbs up RS4 Start Button Installation Notes
    With a little help from Nigel I got my RS4 start button installation completed on Sunday.
    I've documented the entire procedure and have posted it here:
    http://audiretrofit.quinlivan.net
    I've also put the notes from my PhatNoise instalation up. I'll add other stuff to the site as more mods are completed.
    L60N
    Awesome write up and very well layed out explanation wise!! Mega props
    Im just thinking its a great amount of work required as an alternative to turning the key one more click
    Dec 2006
    Ireland
    2,538
    Yeah, but for sheer novelty factor alone it is worth it!
    L60N
    No doubt!
    And you obviously like tinkering so what better way to do it than with your car
    Dec 2006
    Ireland
    2,538
    Exactly..... it keeps me off the streets and out of mischief!
    On Boost
    Manchester
    1,756
    Good write up mate , i don't think it's for me though.....i'd rather walk on the wild side
    p
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by phantom View Post
    p
    That song just happenned to kick in at that point when I turned the ignition on - although it does add a nice soundtrack to the video!
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Very comprehensive write up it has to be said - well done Marc!
    Jon
    Now A3 less......
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    I had mines fitted by my Audi Dealer last week. They said that they followed the wiring diagram of the RS4s ignition wiring and took them roughly 2 hours to do.It works a charm and looks the part too! Thanks to you guys I now have something unique on my S3
    2012 RS3 / Daytona Grey / Alu pack / revo3+ / LOBA500P / LOBA CNC Intake pipe / LOBA HPFP / Forge Race FMIC / Milltek resonated exhaust / revo intake system / Devils own WMI / 20" BBS CH-R Titanium / H&R Monotube coilovers / H&R Anti Roll bars / Alu Roof rails / Hybrid RS grille / R8 paddle shifters /
    Dec 2006
    Ireland
    2,538
    What did they charge you for the priviledge?
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    Quote Originally Posted by MarcQuinlivan View Post
    R800(divide by 15) and that included the plug module below the start button. I see that the invoice also states wiring harness.
    Dec 2006
    Ireland
    2,538
    800/15 - Is that STG53? If so then that was a steal! My button and cigarette lighter came to STG90 just for the parts then the connector was about a fiver. Add two hours' labour to that and it is a lot more expensive!
    I know if I was to source all my parts down here rather than the UK it would have been about 210 for the parts and then 70+VAT per hour for labour is 170 so about 380. Although, I doubt that my dealer, or even a UK dealership would do the work anyway.
    blackcruiser's Avatar
    A3 Sportsback 2006
    Nov 2005
    Singapore
    48
    May I know if this retrofit works on the DSG models? TIA
    Feb 2008
    Europe
    231
    Hi Marc,
    Excellent description! Thank you for your fantastic work. I started the thread with very little knowledge but you perfected it.
    cheers!
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by blackcruiser View Post
    No reason why it shouldn't. The wiring of the button does not go near the gearbox. Like I said in the notes, the key based system which you currently use takes the 12v switched feed from the yellow wire, and when you turn the key to the START position it sends it through the barrel to the red wire and out to the starter motor. All the button does is take the yellow feed from just outside the barrel, run it down the button and when you press the button it closes the connection and sends the 12v signal back to the red wire. If your car will start with the key, then it will start with the button.
    With a DSG model you need to have it in park with your foot on the brake to start the engine - is that correct? The same will apply with the button as the start procedure is still the same - only the mechanism for putting 12v onto the red wire has changed.
    A3 Sportsback 2006
    Nov 2005
    Singapore
    48
    Thank you for the great info. Appreciate it.
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    Marc, do you want to post this in the FAQ's sticky thread at the top of this section? Would be a shame to put document this info only for it to be lost over time as the thread disappears!
    J.
    Married and blonde yes, but still a guy with a poor taste in usernames!
    Mercedes Benze E-class 350 sport convertable, black, pacha grey leather, 19" AMG rims, HK stero and a few more toys
    VW Scirocco 2.0Tsi GT with Revo stage 2, evoms induction kit, lowered, short shift, miltek
    BMW 330 Coupe M sport Black, Black leather, Nav and a lot of other options.
    BMW Z4 Coupe Sport in black with a few toys - going friday and gonna be missed by my lad.
    A3 2.0Tdi S-Line DSG. Gone but not forgotten
    Dec 2006
    Ireland
    2,538
    Cheers MB. I've put it in there now.
    Hadn't even realised that section was there.
    Jan 2007
    Nottingham
    Hi, I like the spound of the start button, tried connecting to the link but it failed, is the site no longer available?
    Regards
    Nigel
    Dec 2006
    Ireland
    2,538
    Shouldn't have failed - try this copy: http://audiretrofit.googlepages.com/
    Dec 2006
    Ireland
    2,538
    Looks like this install is generating some interest on other audi forums. Nobody seems brave enough to try it yet though!
    http://66.102.9.104/translate_c?hl=e...nxt7CMaGmDSKyw
    http://forums.vwvortex.com/zerothrea...ostid=49194500
    Kontraband's Avatar
    Dec 2007
    1,998
    HAHAHA yeah, I certainly wouldnt be brave enough... I had it all on installing/deinstalling my phone kit in the last car. Was well worried I was gonna break some facia, scratch a panel etc etc.
    Cracking job tho.
    27,126
    The testbed for this mod was done on my DSG A3 so yes it does work, should work on all TBH as Marc followed my wiring to the letter so alls good.
    I went a step further & built a pcb with fuses inline & diodes to protect the original starter circuit & the rs4 button from surges or unneeded voltage down either circuit, but after my wiring marathon through the car you could get away without this, I'm just over protective when it comes to important circuits, so like to have it safer than most.
    27,126
    **** Marc we're famous, lol, add my name to title of the book, you wait until I've done my mirrors & full closure, lol, god,
    Dec 2006
    Ireland
    2,538
    Yes - credit where credit is due.... you did do all the leg work for the ignition wiring.
    27,126
    I'm gearing up for my seat on Jonathan Woss come friday.
  28. #27
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by nigelhobden View Post
    .... and here on this Cumbrian Audi site too.
  29. #28
    Kontraband's Avatar
    Dec 2007
    1,998
    Quote Originally Posted by JohnS3 View Post
    BWAHAHAHA
  30. #29
    27,126
    gotta be some way to make money out of our fame, lol.
  31. #30
    A3 Sportsback 2006
    Nov 2005
    Singapore
    48
    Thank you so much. This is the assurance I need before getting down to the project.
