Chris NottEM Tuning
    Sep 2006
    Surrey
    1,224
    Rear Right Brake Light Bulb Gone - Easy To Change?
    Hi all. Just yesterday I got a DIS Warning about my Rear Right Brake Light Bulb gone and it needs to be changed. I checked and it does.
    Now is it an easy job to do it yourself or would I be better of getting someone else to do it? Also what kind of bulb does it require?
    Many thanks!
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    Dec 2006
    Ireland
    2,538
    remove the circular cap inside the boot, then use a flat headed screwdriver to remove the plastic bolt and then pry the light off from the tailgate side to the side of the car. there are two ball pin thingys holding it on. the bulb can then be replaced. do the opposite to replace the glass.
    Sep 2006
    Surrey
    1,224
    Thank you =) Will have a go at it later
