JMB RetrofitsBadger5
    EAGLE79's Avatar
    Nov 2006
    340
    Removing Wing Mirror Glass
    Anyone got any good tricks or methods (tried & tested) that i can use. Wanna change my mirror housings but scared of breaking the glass, especially at 70 a pop.
    Help most appreciated, thanks in advance!
    2008 S3 in Ibis White
    291BHP! STANDARD on 95ron Fuel. Get In.
    All Hail Mitch78
    On Boost
    Manchester
    1,756
    Ive tride once and cracked the glass.
    Ive been told/found out since that if you heat it up with a hair dryer it makes it slightly bendy and less likely to crack.
    p
    Nov 2007
    253
    look under the casing and you'll see two small phillips screws - un-screw them and unclip the lower section of casing off (use a taped small flat head as it helps to prevent sratched and marks)
    the mirror is held on to the backing plat with a circular clip - you'll only be able to see the catches from this side
    flick them back through the hole and disconnect the cable - job's a good'un
    Jan 2007
    Hampshire
    1,155
    I popped mine out when I upgraded to auto-dimming mirrors. I found that by electrically moving the mirror down as far as it will go, this gives enough room to squeeze your fingers behind it. Neither of mine broke when I removed them.
    A6 3.0 TDI.
    JimmyJames's Avatar
    Jas.
    Sep 2007
    Linlithgow, Scotland
    201
    As Phantom suggests. Yes the hair dryer method works. I did mine on my old sportback from Black to Chrome and back again when traded in.
    Do the 2 screws as well allows for a bit more play after heating the mirror. It will be easier to release from its fitment, then the 2 wires for the heated mirror and its OFF.
    No problem
    S3 57 Dolphin Grey.
    MFFBSW,GSM,Cruise,Symphony 6,Bose,
    I-Pod,Rain n Light Pack,Front Arm Rest,Black Optik Grille,BBS Calito'S.
    06 A3 2.0T Q S-Line Sportback Spec Ed. Sold
    05 TT Quattro Sport (240 bhp). Sold
    04 A4 1.8T S-Line (190bhp). Sold
