Badger5EM Tuning
Results 1 to 10 of 10
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    Carpy25's Avatar
    Oct 2007
    272
    Sorry for being dull but whats DRL's read both your posts about this and i'm dull ?
    Rob
    mitch78's Avatar
    Mar 2007
    2,723
    Ex 8L S3 driver
    Carpy25's Avatar
    Oct 2007
    272
    got it so when you switch you dipped lights on they go out . the dipped feed goes to the DRL relay and switches it off so the easiest way would be to replace the cut feed with another one triggered from the dipped feed
    simply put a live to the DRL with a second 12v supply that only works when the dipped lights are on , should be easy to do
    does this make sense
    Rob
    mitch78's Avatar
    Mar 2007
    2,723
    Ex 8L S3 driver
    I'mRonBurgundy?'s Avatar
    Lets make that kitten purr...
    543
    Now I'm feeling a bit thick cos if they were Daytime Running Lights wouldn't they be on all the time anyway? Isn't that the point of them?
    2008 A3 1.8T FSI S-line Phantom Black, Bose, iPod Dock, Front Centre Armrest, Storage Pack, Aluminium Pedals, H&R Spacers, Eibach Pro's, Ambient Lighting, Pressed plates with Ingolstadt surrounds.
    mitch78's Avatar
    Mar 2007
    2,723
    Ex 8L S3 driver
    Dec 2006
    Ireland
    2,538
    Should be something in VAGCOM for that. I'll take a look later.
    Kontraband's Avatar
    Dec 2007
    1,998
    Why do you want them on Mitch?? Asthetics?
    Only noticed myself a couple of days ago then went off when the headlights came on, as I set behind a chelsea tractor admiring my xenons.
    Thought they may look better 'fully lit'?
    mitch78's Avatar
    Mar 2007
    2,723
    Ex 8L S3 driver
