Although the new SE will be a lower spec than the existing SE it's also only a £650 option rather than the current £2000. If you add back all the items from the present SE spec to a new SE it works out at approximately the same price. It does allow you to choose which options you want and which you don't.
They are still available if you want them!. For the Standard and SE they will be be Pearlescent in Granite, Umbra or Opal depending on the interior colour chosen or Walnut wood, for the Sport they will Aluminium medial or Walnut wood, For the S-Line Matt brushed aluminium or Piano, and for the S3 Matt brushed aluminium, Piano black or Fine grain birch wood depending on the model.
Few companies/business users would bother though. Go to any leasing website, look up the A3 and they plug the standard or "Special Edition" model which is vastly cheaper, and also why you see so many around.
