Chris NottAH Fabrications
    Aug 2006
    41
    AIR CON NOT WORKING ?
    Hi,can any body help me with the problem,the air con in my car is not working properly in the recent spell of hot weather i have had the settings on low but it is only blowing out hot air.
    does the system need regassing ?
    I have VAG COM but it does not show any faults.Is there a way using VAG COM to see if it does needs regassing?
    ANDY
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Does the ECON light stay on permanantly?
    It most likely needs regassing yes.
    With the engine running, the ECON mode disabled and the temp to LO in Auto check under the bonnet that the fan on the front of the car on the right (as you look at it) is spinning.
    Also get someone else in the car to press the ECON button on and off while you look at the compressor (mounted to the left of the engine and driven by a belt) and make sure as the button is turned on and off that the clutch is going in and out. You should hear the clunk at least.
    8P2 S3
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    You've either got it on ECON where the compressor doesn't kick in to save fuel, or it probably just needs a regas. To stop this from happening again you should use the air con on the lowest setting every so often, to keep the juices flowing, so to speak.
    Aug 2006
    41
    thanks for the info guys i will check the clutch and fan the econ light can be switched on and off however i never use the econ button and my air con is on all the time i do not switch it off as i use it as climate control should be used to regulate the temp in both summer and winter conditions
