Volks AutosChris Nott
Page 2 of 2 FirstFirst 12
Results 41 to 46 of 46
  1. #41
    Dec 2006
    Ireland
    2,538
    これで、ここでは、少数の歴史と語ったが必要だ 無名の英雄 この土が削除されます ある人は、継承はされています 造幣局からの輸入 人々の多くがないのにネウルエウンイ 事実、この老いたहेごみमेरे 彼は帽子にゴミ収集した これは、うわっイレオルスがズボンです そして彼は、フラットに住んで協議会
    彼は'真のनानाである 大きな皿の後に起動チクヒギル 彼はउन्हें得ることができる職業を持って 彼は根が何उन्हेंデイジー電話
  3. #42
    RacingTeatray's Avatar
    Freezing in Moscow
    Oct 2004
    Moscow
    244
    Perhaps Halfords are just idiots. It wouldn't be unheard of. I have Parrot systems in both my Alfa and my Merc, and they both cost well under 200 quid fitted. I had the dealers fit them when I bought the cars (second-hand) and they both did immaculate jobs - neither has ever gone wrong. Certainly, the main dealers will do this for you if you don't want to fork out for the fully-installed factory kit (385 quid is a bit steep, though not as steep as the 535 quid BMW charge!).
    Ex S3 owner.
    Now making do with a BMW Z1, Mercedes 500E and Alfa 156 GTA
  4. #43
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Mike - Just fitted an MK6100 to my A3 to replace a previous CK3000.
    Mine is a non-Bose ConcertII headset, so this might be different for you but mine was very straightforward.
    1) The Parrott ISO connectors simply slotted into place in the back of the head unit - taking the permanent live, earth and the speaker feeds.
    2) There's a wiring diagram on the head unit, showing which the "Tel Mute" input is on the radio. I bought a little 2mm spade connector and connected the Parrott "Tel Mute" wire onto the right connector pin on the back of the head unit as shown on the head unit wiring diagram. (It was none of the pre-wired parrott options that go into the Parrott wiring loom, so don't use them)
    3) I cut the orange "ignition feed" wire as you rightly say, the Canbus system doesn't provide a switched ignition feed to the head unit.
    Instead, I extended that orange wire and connected it into the fuse box at the right end of the dashboard.
    The picture in MarcQuinlivan's post (number 21 above) shows the idea. I got a spade connector and filed it down so that it would simply push into one of the spare unused connectors on the front of the fusebox.
    Some are live all the time and some are "switched ignition" live feeds, so you need to use a tester or use trial & error until you find one that goes off when the ignition goes off....
    Easy job overall...
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
  5. #44
    MikeSel^'s Avatar
    Systems Support Specialist
    Oct 2008
    Hull, UK
    554
    Thanks guys
    I've a mate coming round tommorow night to get this install sorted once an for all!
    I will let you know how it goes.
  6. #45
    Jay.Ing's Avatar
    Jun 2008
    North West
    264
    Di it yourself mate, its very easy, i installed one in my old Ibiza FR and ive installed an aftermarket H/U in my A3 running a swithed live from the Fusebox!
    2012 A3 Ibis White SportBack Black Edition 140
    Mods so far: H&R 50mm, Rain Light Sensor, RNS-E, Cruise control, Interior OEM LED mood light, OEM LED number plate lights, OEM LED Puddle lights, OEM LED Footwell Lights, tear drop wiping, Beep confirm on close, pressed plates, HHA & TPMS.
    Red A4 Black Edition 150Tdi.... On order!
    Gone But Not Forgotten....
    2011 A1 Black Sline 106
    2006 A3 Red Sline 140
  7. #46
    MikeSel^'s Avatar
    Oct 2008
    Hull, UK
    554
    Finally got mine sorted Thanks guys for the instructions.. Off to Maplins at the weekend to get the spade connectors to do the tel mute bit.
    Has anyone taken the back of the 'coin holder' out? IE the center console under the climate control controls, and radio etc? I want to mount the screen there, so want to lead the cables through that bit, but not sure how to get it off...
    Sorry for the vague description, I will post pics when I get a mo.
