Results 1 to 13 of 13
    sprout99's Avatar
    Jun 2006
    North East - Dodge city
    367
    Lumpy tick over and random stalling
    anyone had this with DSG TDi?
    Our's has just started this random act. Tickover is occaisionlly lumpy and it has stalled a few times of late just as you're about to pull away.
    cheers
    2004 AUDI A3 S-LINE DSG TDi
    MAURITIUS BLUE
    2005 BMW 120d M Sport 163+
    BLACK SAPPHIRE
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    I would suggest getting it scanned for any DTCs as a starting point.
    Regards,
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    sprout99's Avatar
    Jun 2006
    367
    It seems to only happen when air con is on.
    As if the extra load on engine is not being compnesated for.
    Anyone know how / what does this on the 2.0 TDi?
    I's like to have an idea before approaching the stealers.
    MAURITIUS BLUE
    BLACK SAPPHIRE
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by sprout99 View Post
    Bloody hell, everyone seems to be having air con problems today!!
    Strange fault this though. Are you 100% it's only when the air con is on? The compressor should only add about 5bhp load on the engine so it certainly shouldn't be making you car stall. A hill would make more of a difference!
    8P2 S3
    Aug 2007
    437
    Perhaps the idle speed is set a little too low. Whilst the 5bhp doesn't sound much the engine is idling....
    A3 2.0TDI Sportback S Line 184 Quattro S-Tronic, Mar. 2014 Glacier white. Electric seats, sunroof, se suspension, heated folding mirrors, Reversing camera, Nappa leather, TPMS, Hold assist, Xenon plus adaptive lights with variable active range control, lane assist, Interior light pack, Technology pack, Comfort pack with ACC, park assist & parking system plus
    Jan 2005
    cambs uk
    1,139
    doubt that the tickover being set low could cause this as the ecu would compensate
    I'd say get it checked over, sounds badgered to me
    27,089
    I would say based on with aircon running & pulling away it is idle speed is to low, there is an idle sensor isnt there for this that has been known to be intermittant even on earlier 8L cars, do a VAG 1st, then look at idle speeds, when you pull away with air con running did you check the idle rpm in dis to see if drops low cause thats a 1st quick look, not dead on balls accurate but an idea, but if you think it through it does point to this given the extra load put on by the aircon system, if a sensor is out of whack then the ecu wouldnt know to compensate.
    Just my thoughts.
    sprout99's Avatar
    Jun 2006
    367
    cheers fellas
    i've been out playing the car shudders very slightly during tick over like a small surge so maybe the idle thiny is a bit dodgy. A bloke who i work with mentioned something along those lines and if dodgy MPG's would suffer .....just checked the mpg's ........42 !!
    thats fecking rubbish. the old 8L of the family does 50 nee bother with masses of good flogging.
    i've been up and down the back road like a banshee it's certainly going alright but somethings not quite right with her ( i blame our lasses driving ;-)
    I'll try and get a VAGCOM scan done on it.
    MAURITIUS BLUE
    BLACK SAPPHIRE
    Feb 2007
    Hampshire
    1,654
    I'll let you know how I get on changing my coolant temp sensor.
    I had a real lumpy start this morning, but it didn't stall.
    Paul
    VCDS HEX-USB+CAN
    sprout99's Avatar
    Jun 2006
    367
    cheers - i'm interested to know......
    also if you check mpg's off tank
    we got 46 on bank holiday monday but i drove steady 95% of the time
    MAURITIUS BLUE
    BLACK SAPPHIRE
    sprout99's Avatar
    Jun 2006
    367
    Quote Originally Posted by Gti Jazz Blue View Post
    Regards,
    Paul
    just had it scanned ....nothing
    So while he was on got anti-hijack switched on for the lady all for 20
    MAURITIUS BLUE
    BLACK SAPPHIRE
    sprout99's Avatar
    Jun 2006
    367
    i think another fuel filter and a shot of concentrated injector cleaner.
    the fuel filter is black and was only changed a short time ago.
    MAURITIUS BLUE
    BLACK SAPPHIRE
    Apr 2011
    Did you find the solution to the cutting out problem with air con on as I am now getting the same problem on my a3 tdi dsg?
