Page 3 of 7 FirstFirst 1234567 LastLast
Results 81 to 120 of 266
  1. #81
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by marriedblonde View Post
    you could always save your fuel and bluff them by making engine noises...
    that only works when i'm going down hill!
  3. #82
    Kontraband's Avatar
    Dec 2007
    1,998
    Quote Originally Posted by MarcQuinlivan View Post
    Who is this MarkQ chap?
    He's stangely like you Marc.
  4. #83
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by Kontraband View Post
    sorry, thought it was time to make a stand on that one!
  5. #84
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    If I can't get it to work I can always try to bluff my passengers by turning the key at the same time as pressing the button!
    LOL Genius!
    Anyway sorry MarcQ,
    Do you know much about the immobiliser? As I was saying before it's only a case of touching 2 wires together to start the engine in basic terms. I've heard of immobilisers that work because the key sends a signal into the ignition when the key is in it. If that is the case then it will only be a case of stripping down the steering column and finding the right wires.
    8P2 S3
  6. #85
    Dec 2006
    Ireland
    2,538
    Yeah, there's a transponder in the key which communicates with something in the steering column to deactivate the immobiliser.
    I'd be happy enough to just hook it into the starter cable rather than bypassing the immobiliser - at least that way i'll still need the key to start it. A car thief's job would be made so much easier if all he had to do was get in and press the button.
    Anybody know which wire from the ignition feeds into the starter motor?
  7. #86
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Well you wouldn't be bypassing the immobiliser, that signal will go via another route to the ECU. Once you have the steering coloumn off you can find whichever wire it is easily and then do the mod there and then.
    8P2 S3
  8. #87
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by staz1000 View Post
    But I'll still need to have the key in the ignition, right?
  9. #88
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Yep
    8P2 S3
  10. #89
    S.3THRIZZLE's Avatar
    S.3RIZZLE.....
    Mar 2008
    ENGLAND
    66
    There is one major problem with keyless go which to my complete and utter dismay I only realised a few weeks ago, 250 miles away from home and unable to leave my car !!! basically my brother had arrived home in his car and jumped out leaving the ignition running, I had been waiting for him so there was no need to stop the engine and lock it etc, problem arose when I arrived in london ( I live in manchester) only to find the idiot had started the car initially with keyless go and kept the key in his pocket............. so I couldnt switch the engine off, if i did i couldnt lock the car and it wouldnt start again.... Possible the most fun spent in an ncp ever !!!! still the new CL has a great dvd player in the dash..... thankgod for the dvds lying in the boot !
  11. #90
    Dec 2006
    Ireland
    2,538
    I know from experience that the Mercedes S600 and the various Bentley Continental variants display a warning in the dash if the transponder is not inside the car when you close the door.
  12. #91
    S.3RIZZLE.....
    Mar 2008
    ENGLAND
    66
    youre right the bentley does but as for the cl i didnt notice anything
  13. #92
    Nov 2007
    253
    I guarantee the novelty will wear off within 2 weeks
    had one as standard fit on a previous car and using two hands, fumbling around in the dark to start the car was a pain in the arse
  14. #93
    RAC 500W
    Apr 2008
    Coventry
    180
    Yeah but its still fun and cool for a fortnight, lol.
    Rich
  15. #94
    Dec 2006
    Ireland
    2,538
    I've already placed my order with my dealer. As luck would have it there's a dude on eBay selling bits from and accident damaged RS4 Avant.
    He has this for sale.
  16. #95
    RAC 500W
    Apr 2008
    Coventry
    180
    Ive got to say im pretty envious of all your mods Marc, lol. Everything you seem to be doing is something i would like to do with mine when i get it. Good job mine isnt red as well.
    Rich
  17. #96
    Feb 2008
    Europe
    231
    Hi Marc,
    Will be eagerly waiting to see the results. Good luck!
    klik
  18. #97
    Dec 2006
    Ireland
    2,538
    I'll be collecting the bits on Friday morning, so should hopefully get to the install at the weekend. Just need to get the button into my hands to see what connector is needed for it.
    I assume it is going to be something like the ESP button with three wires - earth, lights and then the third wire is for the ignition.
  19. #98
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Four wires I'd say + & - for the light and then input and output for the ignition.
    8P2 S3
  20. #99
    Dec 2006
    Ireland
    2,538
    My mistake - I was thinking about when I installed those illuminated buttons from Cargravo.
    It is a 6-pin connector for the ESP button, but the Cargravo buttons have a connector which takes a tap off two wires for the lighting.
    Obviously the button needs an input and output pin too. Sure, I'll soon find out!
  21. #100
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Although it could work from 3 as it could use the ignition input to power the light. I'd recommend this anyway to save on wiring!
    8P2 S3
  22. #101
    Dec 2006
    Ireland
    2,538
    Think I'd prefer the light to be powered using the illumination circuit for the rest of the instrument panel\dash buttons. That way it'll be lit when the lights are on.
    I've been reading where some people have hooked an earth from the ignition relay into the handbrake so that you can only start it when the handbrake is on.
    I'd kinda like to stop some curious passengers from pressing the button while i'm driving, but don't want to have to apply the handbrake in order to restart the car if it happens to cut out while pulling out of a junction or on a level crossing. Might see if there's some way to hook it into the relay for the brake lights so that I have to have my foot on the brake to start it.
  23. #102
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    But if you do that it'll be lit only when the lights are on, do you turn the lights on before you start the engine? The way I was suggesting means it is lit all the time when the ignition is on.
    I don't know why anyone would want to only be able to start it with the handbrake on, for the reasons you have suggested. But the brake idea is a good one yes. It'd be worth finding out if the alternator has an auxillery output, you could then use that to inhibit the starter button when the engine is running. I guess you could use the alternator warning light output to inhibit the circuit though also.
    8P2 S3
  24. #103
    Dec 2006
    Ireland
    2,538
    Was stopped at a set of traffic lights on the way home and decided to see what would happen if I gave the key a quick turn. Nothing happenned. Seems to be some sort of wizardry at play to disable the ignition if the engine is already running. That should mean that the button also won't work if the engine is running.
    The button only needs to be lit when the rest of the instruments are lit I think. The interior lights are on when before the key is turned to accessory so finding the button won't be a problem.
  25. #104
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I did wonder myself whether the key was inhibited from turning to the start position phisically of if it is as you say. In which case yeah if you take the feed from the right place then you won't have problems if someone presses the button.
    Aha you meant the interior lights feed! Not a bad idea but the lights go off when you turn the key to put the ignition on. I still think an ignition feed coupled with an alternator aux/warning light interlock would be perfect. i.e. you turn the key and the light comes on with the ignition you press the button and once the engine is running the light extinguishes.
    8P2 S3
  26. #105
    Felix A3's Avatar
    Apr 2008
    23
    You will probably find that there is a relay controlling the starter motor.
    One side of the relay coil will be fed from the ignition switch when you turn it to the crank position (usually a positive feed), the other side of the relay coil will be fed by the engine ECU (usually an earth). This enables the ECU to stop the starter from engaging when the engine is running.
    So as long as you fit the starter switch between the ignition switch and the relay you shouldnt have a problem.
  27. #106
    Feb 2008
    Europe
    231
    As a safety feature, on the RS4 when you turn ignition key the DIS says to press the clutch pedal and press the start. hope this helps.
  28. #107
    Dec 2006
    Ireland
    2,538
    That actually makes more sense. It means that the car cannot be started if accidentally left in gear. I'll have a more detailed look at the weekend after I've picked up the stuff tomorrow.
  29. #108
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    It also does this on the S3 Marc and I was going to suggest this but I thought you knew. The problem is it most likely uses a switch on the clutch master cylinder to recognise whether the clutch is depressed or not. On a non S3 model this switch won't be there and I doubt there would be fittings for it either.
    8P2 S3
  30. #109
    Dec 2006
    Ireland
    2,538
    Yeah, I've just been looking at ETKA and the RS4 has a clutch switch and a brake switch in behind the pedals but the A3 does not.
    I do remember seeing a photo of someone's S3 with the "press clutch" warning in the DIS now that you mention it.
    I suppose if I can intercept the signal for the brake lights that will be enough.
    The parts have just arrived with the dealer, so I've asked him to see if he can work out which connector I need for the bottom of the button.
  31. #110
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    What about for the S3?
    8P2 S3
  32. #111
    Dec 2006
    Ireland
    2,538
    couldn't see one. might have another look on ETKA later.
  33. #112
    I'mRonBurgundy?'s Avatar
    Lets make that kitten purr...
    543
    I don't have an S3 but do have the Press "Clutch to Start" function. Thought all A3's had this tbh.
    2008 A3 1.8T FSI S-line Phantom Black, Bose, iPod Dock, Front Centre Armrest, Storage Pack, Aluminium Pedals, H&R Spacers, Eibach Pro's, Ambient Lighting, Pressed plates with Ingolstadt surrounds.
  34. #113
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by I'mRonBurgundy? View Post
    Is yours a manual? Perhaps it is only the manual ones that need you to press the clutch on!
    Mine isn't as S3 and doesn't have this on the display.
  35. #114
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Quote Originally Posted by klik View Post
    That's there for a very good reason!
    On the RS4 the start button connects to the ECU and all it does is "initiate" a start sequence. So all you have to do is tap the start button for a fraction of a second and the starter motor will run until the engine starts (or a timeout period) - so if you didn't have the clutch pressed your RS4 could be motoring across the car park if you had left it in gear!
    So you can put on your seatbelt while the engine is starting because you have both hands free.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
  36. #115
    543
    Yes mine is a manual. If it wasn't I wouldn't have a clutch pedal!
  37. #116
    Dec 2006
    Ireland
    2,538
    Really? Must have forgotten to add the "[sarcasm]" tags there.
  38. #117
    DeckedS3's Avatar
    Apr 2008
    South East
    551
    Quote Originally Posted by boggysv View Post
    Threadjack: does anyone's knob glow like this? I like it, but mine doesnt seem to glow.
    (please excuse the homo-esque question)
    Sorry to jump in... Is this possible to do on the S3? The glow around the gearshift looks great!
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
  39. #118
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by DeckedS3 View Post
    Sprechen Sie Deutsch? http://www.faudiq.de/anleitungen/Int...beleuchten.htm
    Or here's google's dodgy translation attempt:
    http://66.102.9.104/translate_c?hl=e...beleuchten.htm
  40. #119
    Felix A3's Avatar
    Apr 2008
    23
    Not sure if i would risk destroying 90 worth of S3 gearknob for a few LED's.
    But fair play to him it does look impressive
  41. #120
    RAC 500W
    Apr 2008
    Coventry
    180
    I like the look of it as well but im not sure it would be quite as straight forward as the guide would lead you to believe.
    Rich
