EM TuningBadger5
Results 1 to 14 of 14
    Stevie C
    Mar 2008
    Bristol
    153
    Progressive Steering Code anyone?
    Hi does anyone know the code to set up progressive steering via Vag-Com?? Heard it has been done!
    Audi A3 2.0 TDI Dolphin Grey |Loads of extras... & Mods...
    Mods Fitted - Full Rieger Infinity Body Kit including Splitter | De Chromed Front Grills | Graphite RS4 19" Alloys |MK5 Golf GTI Brakes |S6 DRLs | Jetex Twin Tailpipe Exhaust | Revo Remap | TT FBMFSW |S3 Retro Pedals | S3 Air Vents | Diamond Front Component Speakers | Custom Parcel Shelf |Private Plate
    Mods to be done - R32/R line Gear Knob | Interior Map lights |35% tints
    warren_S5's Avatar
    Oct 2007
    7,166
    Quote Originally Posted by Stevie C View Post
    Here are codes for Leon Mk2 Cupra - very similar to our cars:
    One Touch Indicators (Comfort Indicators)
    This turns on or off the one touch lane indicator which gives you three indicator blinks on a sungle touch. This is on by default.
    Module 09 - Cent. Elects.
    Coding
    Byte 2
    Bit 8 - Comfort turn Signals
    Leaving Home Lights
    This feature turns on your lights when you unlock the car (if your headlight switch is on). I believe this option is standard if you have the auto lights option. This also adds an option in the MFD lights menu for how long it will stay on.
    Coding
    Byte 0
    Bit 5 - Assistance Driving Light_Leaving Home active
    Coming Home Lights
    This turns on or off the feature, where it leaves you lights for a short period on after you get out the car. This can also be changed via the larrger MFD if you have it.
    Coding
    Byte 0
    Bit 7 - Coming home active
    Coming Home Lights Active Time
    This sets how long the comning home lights styay on for. This can also be set through the larger MFD if you have the bluetooth option.
    Adaptation
    Ch.01
    Set a value between 10 and 60 seconds, must be in 10s.
    Emergency Brake Flash
    Im am not sure this features works, I have the option, but does not seem to activate on mine, may be a model year dependant feature.
    Coding
    Byte 17
    Bit 0 - emergency brake flash light active
    Turning Off Sealt Belt Warning
    Module 17 - Intruments
    Coding
    Change 3rd and 4th number in string to 00 as per text comment, or add up the number for the options you have, ie; you have headlight washers if you have xenons, so add that to the value.
    Selective Central Locking (single door opening)
    By default, when you press the keyfob to unlock the car, it only opens the drivers door with a single click. If you turn this features off, it will unlock all doors with a single click.
    Module 46 - Central Conv.
    Coding
    Byte 0
    Bit 0 - Selective Central Locking
    Automatic Window Closing/Opening
    This enables all the windows to close or open if you hold down the lock/unlock button on the keyfob, and or holding closed/open the keylock on the door
    I have found on newer cars (MY07?) these features are already active, but on my MY0 I had to activate it.
    Coding
    Byte 4
    bit 0 - Comfort opening power windows via door lock active
    bit 2 - Comfort opening power windows via remote control active
    bit 3 - Comfort closing power windows via door lock active
    bit 5 - Comfort closing power windows via remote control active
    Beep when locking/unlocking car (My favourite feature)
    This adds a beep when locking the car, and two beeps when unlocknig the car.
    Below; horn refers to the beep, and blink refers to the indicators blinking
    Coding
    Byte 6
    bit 0 unlocking confirmation (blink) via door locks
    bit 1 - unlocking confirmation (horn) via door locks - (makes 2 beeps)
    bit 2 - unlocking confirmation (blink)via remote control
    bit 3- unlocking confirmation (horn) via remote control - (makes two beeps)
    Byte 7
    bit 0 locking confirmation (blink) via door locks
    bit 1 - locking confirmation (horn) via door locks - (makes 1 beep)
    bit 2 - locking confirmation (blink)via remote control
    bit 3- locking confirmation (horn) via remote control - (makes 1 beep)
    Syncronised Mirror Adjustment
    Syncronised mirror adjustment, is the feature that automatically moves the left mirror when adjusting the right mirror. This is on by default.
    Coding
    Byte 9
    bit 6 - Synchronised mirror adjustment
    Anti Hijack
    This locks all doors when the car moves above 15km/h. This is on by default.
    Module - Central Conv.
    Adaption
    Ch.0
    1=on 0=off.
    Steering Weight
    Module 44 - Steering Adjust
    Adaptation
    Ch.01
    Select a value between 1 and 6 for weight.
    Volume of Reversing Sensor beep
    Module 76 - Park Assist
    Adaptation
    Ch.01
    Select value between 0 and 100. Default 60
    Changing Bluetooth Pass Code
    Module 77 -Telephone
    Adaptation
    Ch.15
    Choose a 4 digit value.
    Audi S5 3.0V6T Coupe Black Edition
    JohnS3's Avatar
    Oct 2004
    3,021
    Im sure that doesn't work for 07 and onward cars.
    Dorsprung Turch Vechnique
    Sep 2007
    Glasvegas
    162
    So you have to have your light switch turned to on for this to work?
    Bit strange, gievn that when you turn off your engine, and open your door the lights chime goes off - so what, you just leave them on, lock your car and walk away?
    And you're battery goes flat.......
    More description please!
    2003 - A3 Volcanic Black 1.6i 8L
    2004 - A3 Ming Blue 1.8TQ 8L
    2005 - A3 Dolphin Grey 2.0FSI 8P
    2006 - Driving sabbatical ;-)
    2007 - A3 Ibis White 2.0TFSI 8p
    2009 - A3 Monza Silver BE 2.0 TDI 8p
    Jul 2007
    Hull, UK
    111
    Quote Originally Posted by Ian_C View Post
    It requires the auto lights option - I have it and it works great.
    Audi A3 Sportback SE 2.0 TDI 170 - Lava Grey, Rear parking sensors, Symphony II+, Aluminium Trim
    Aug 2005
    West London
    850
    Quote Originally Posted by JohnS3 View Post
    Thats correct it wont work on any S3s.
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
    warren_S5's Avatar
    Oct 2007
    7,166
    why is that? is it just not available or is it that it has changed to something else?
    JohnS3's Avatar
    Oct 2004
    3,021
    It's changed to something else but no one has found out where it is.
    Stevie C
    Mar 2008
    Bristol
    153
    Awesome thanks very much for all the codes :-)
    Sep 2007
    Glasvegas
    162
    Yeah yeah i know, my old A3 04 plate had auto lights, and i really liked the lights coming on when i opened the car - but my new one doesn't have auto lights :
    Can i progamme the car so that the lights come on when i open it? (Even though i don't have autolights?)
    Sep 2007
    Glasvegas
    162
    -Anyone?
    I want to be dazzled when i hit "open" on my transponder!
    Oct 2003
    up north...
    767
    this should work - the coding for coming home/leaving is separate from auto lights, and has an option to use the auto lights sensor or the preferences (coding) - on the seat altea there is no auto lights but the coming home/leaving works.
    i have auto lights so cant test this - sorry
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    Dec 2006
    Ireland
    2,538
    Tried it on mine (no auto-lights) and couldn't get it to work.
    Sep 2007
    Glasvegas
    162
    Bugger - I thought it woul dbe possible to enable this through Vag-Com?
