Volks AutosChris Nott
Results 1 to 15 of 15
    Stevie C
    Mar 2008
    Bristol
    153
    Brake upgarde for A3 REVO'd 2.0 TDI sport
    Well after just having Cruise and a TT wheel fitted to My early 2004 TDI (many thanks to Mattandrew and the guys at VW Audi Cars Bradford on Avon) the next mod I am looking at is upgarding the brakes as the standard ones just dont fill me with confidence especially as the car is REVO'd.
    The car has 19" RS4 Alloys on so clearance is not a problem but budget is! Would like to change all four corners to poss the new S3 Brakes or i have heard that the brakes on the 170 DSG are larger and wondered if these would do the job.
    Any advice grateful!
    regards
    Steve
    Audi A3 2.0 TDI Dolphin Grey |Loads of extras... & Mods...
    Mods Fitted - Full Rieger Infinity Body Kit including Splitter | De Chromed Front Grills | Graphite RS4 19" Alloys |MK5 Golf GTI Brakes |S6 DRLs | Jetex Twin Tailpipe Exhaust | Revo Remap | TT FBMFSW |S3 Retro Pedals | S3 Air Vents | Diamond Front Component Speakers | Custom Parcel Shelf |Private Plate
    Mods to be done - R32/R line Gear Knob | Interior Map lights |35% tints
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    My Golf was remapped and the brakes were fine, if you are doing serious track work then i'd consider the upgrade, but them if you were doing track work it would be cheaper to buy a track car for the amount you would spend on brakes !!
    The cheapest solution is to upgrade the pads on the front, some fast road Ferrodo pads should do, if you want slightly larger brakes I believe you can use the brackets from the Golf GTi and retain your existing caliper, you would also need the rear splash guard and new discs. Larger brake kits involve new cylinders & everything and would cost 2k to do right.
    Gone A3 TDi S Line DSG Bluefined
    Now Seat Leon Cupra about to be Bluefined
    Low life livin' the high life.
    Feb 2008
    1,638
    I wouldn't agree that a bigger brake kit costs 2k to do it right at all. I've looked into it (started a thread on here somewhere) and you can get a Brembo GT kit for just over a grand, probably 1200 fitted for an A3. Looks smart and classy and is a massive improvement over the stock set up. I've seen some brilliant ATE kits on Ebay for bargain prices before as well (600), then you'd need someone to fit it. Alternatively if you were lucky enough to find some i'd imagine the Brembo's off a Leon Cupra R would fit straight on.
    Either way, it's definitely an affordable mod to have done within reason. I'll be upgrading my brakes definitely. The brake fade at times on mine is a bit scary when braking at speed.
    Paul.
    A3 2.0T FSI Quattro S-Line, 3 Door, Avus Silver (special ed.)
    For Sale:
    S-Line gear knob, stick and gator.
    Full set of OEM wheel bolts (incl. locking nuts & caps)
    19" BBS CK's Anthracite - SOLD
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    I've never got mine to fade yet, surely if you fit larger calipers they are going to require more fluid, that will mean a larger resovior and also a larger master cylinder.
    hatmeow's Avatar
    Turbo is the only way....
    Feb 2008
    247
    Steve,
    There is no need to fit larger master cynlinder nor a larger reservoir. It will need more fluids but it does not mean that a larger reservoir is needed.
    Brembo GT kits should fit without the need for adapters and should not cost 2,000. You can also fit Brembo / Cayenne 6 pot calipers for even more stopping power. Here is what my car looked like after fitting 6 Pot Brembos on
    (Yes I had mine painted in dark grey with silver Audi logo). There was no need for a new cylinder and was just a straight bolt on.
    I had mine changed because I thought the original brakes weren't enough after the MTM remap. Now it stops on a dime!
    However, going for R32 calipers can be another cheaper option and you can look for a set from the breakers. Again, straight bolt on with no additional changes.
    Hope this helps.
    A3 2.0T Sportback DSG.
    Engine / Trans:
    K04, Unitronic Stg II+ & DSG Stg II, S3 Injectors and Intercooler, APR F/Pump. BSH Intake, Forge DV, Oettinger Turbo Outlet, Eurojet throttle pipe, Milltek TBE. SP Meth Injection.
    Brakes and Suspension:
    Brembo 6 pot w/ 345mm slotted disks, TT front suspension, HPA Coliovers, OZ Palladio, 225/40/18 BS RE001
    Others:
    S3 Front, Pedals, & Mirrors, 09 SB Skirts & LED Rear Lights, Original HID retrofit, Oettinger Roof Spoiler. Defi Turbo Guage, FBMFSW
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by SteveTDCi View Post
    I'm with you there.
    One of my regular routes is a quiet B-road.
    Huge long straight, down to a small roundabout.
    Regularly 100mph+, braking down to next to nowt.
    Then another straight, followed by a complex of corners.
    Loads of braking, in quick succession.
    Never, ever, got fade.
    I'd suggest a pad change, as the pads have maybe become glazed.
    Certainly a cheaper option than knee-jerk replacement of the whole lot!
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Stevie C
    Mar 2008
    Bristol
    153
    Wicked can i ask how much this set up cost? did you change the front and rear or just front?
    hatmeow's Avatar
    Feb 2008
    247
    Costs about US$2,000 here just for the fronts, steel brake lines, and the slotted rotors. Should not vary too much in price in UK.
    I just changed the fronts without changing the rears as its very costly (just a couple hundred less) and you dont really need it anyways. Just make sure the brake bias is properly adjusted for the bigger front calipers
    Engine / Trans:
    Others:
    Feb 2008
    1,638
    Quote Originally Posted by Stevie C View Post
    Stevie, like i said above...About a grand for the A3 Brembo kit + Fitting. So call it maybe 1200 all in. Looks the dogs, stops on a dime. Job done.
    For Sale:
    windsurfer
    Nov 2006
    London, Porto
    1,327
    For now standard S3 brake setup is more than adequate for my standard S3.
    No mods planned for my car really.... Saving for a deposit on a new one instead...
    Pedro
    FOR SALE: S3 Phantom Black, left hand drive, Xenons, FBMFSW, bucket seats, BOSE, rear parking sensors, armrest, interior light package, Symphony II+. Full Audi service history and 4 new Michelin Pilot Sport 2. 18500 miles PM for details! I want to give it away have a good family reason. For a quick sale around 19.5k PM only if interest is genuine! Thanks
    Feb 2008
    1,638
    Quote Originally Posted by newbiecrg View Post
    Pedro
    Pedro, you're keeping us all in suspense aren't you...Come on....what's the next car gonna be?!
    Paul.
    For Sale:
    windsurfer
    Nov 2006
    London, Porto
    1,327
    well Paul I think you have a fair idea of what I want... so let's wait and see what happens in the next few months workwise...
    Pedro
    Feb 2008
    1,638
    Good man Pedro, make sure you keep us informed. I wait with anticipation!
    For Sale:
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    Quote Originally Posted by hatmeow View Post
    So how do you adjust the brake Bias ?
    My understanding is that the EBD handles that electronically using the ABS sensors ?
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    hatmeow's Avatar
    Feb 2008
    247
    There is an adjustment at the master cylinder that adjusts the front rear brake bias. I dont know the exact position or the details becuase my mechanic did it for me. Sorry...
    Engine / Trans:
    Others:
