Sky InsuranceVolks Autos
Results 1 to 13 of 13
    Sep 2007
    171
    Amp questions and Line Level OUTPUT from RNS-E?
    Gday all,
    I have an Audi S3 8P with the standard non-Bose stereo system.
    Keeping the RNS-E, I have fitted Alpine amps and speakers.
    The amps receive inputs from the speaker wires that are connected to Alpine speaker-to-line-level converters, and this is alright, but frankly quite poor at the same time.
    Connecting my iPod using a line-out adapter directly into the Alpine amps gave much much better quality, especially the bass which had so much more definition and clarity; this is in comparison to listening to the same song using CD or SD card from the RNS-E. (Aux-In on the RNS-E is further distorted compared to CD/SD)
    Is there a stock amp the RNS-E connects to in the non-Bose system?
    If so, where is it and how do I access it? Does the amp have a pre-out (doubtful)?
    If not, are there seperate speaker out and line out connectors on the RNS-E?
    Am I wasting my time going through the RNS-E if I'm after sound quality? I was thinking if I can't get a decent line level signal out of the RNS-E then to connect the iPod via a seperate EQ in parallel to the Alpine amps so I can retain nav/phone/radio functionality.
    Any comments/opinions/suggestions would be appreciated.
    Cheers guys,
    Daniel
    boggysv's Avatar
    Nov 2007
    572
    C: EXT Control Connector (For Bose or Non-Bose Amp, telephone interface)
    3 - Line Out FL (front left audio signal)
    5 - Line Out RL (rear left audio signal)
    8 - Line Out GND (audio ground)
    9 - Line Out FR (front rear audio signal)
    11 - Line Out RR (rear right audio signal)
    http://www.navplus.us/forums/showthread.php?t=791
    gdluck.
    World's Fastest S3 Driver - racing old people in toyota camries since 1997 with a 97.6% winning rate.
    Sep 2007
    171
    I have been told the stock front speakers run off the RNS-E and rears run off a seperate amp...
    Does anyone know if the front speakers connect to these said line out pins on the RNS-E (don't see how they could be) or do they connect to speaker outs?
    Where is this rear amp? The assumption is that the rear amp gets the line out signal from RNS-E, and amps it to the speakers right?
    The Damned
    Apr 2007
    South Yorkshire
    344
    Quote Originally Posted by cooni View Post
    The rear speakers are driven through the Sub in boot and and I can confirm that the signal feeds for both front and rear are as Boggysv has quoted above
    Sep 2007
    171
    Quote Originally Posted by Von Maximo View Post
    but where abouts?
    this is behind the left hand side, with subwoofer removed.
    is the amp inside that same plastic enclosure?
    or behind the rubber/foam deadening part to the right of it?
    or on the other side (just a large piece of deadening there)?
    The Damned
    Apr 2007
    South Yorkshire
    344
    The amp (if you can call it that) is inside the plastic enclosure. You'll have to destroy the casing to get inside it. Not to sure what you'd achieve by this as the amp wont have any pre-outs as it's designed solely to supply the sub/rear speakers.
    Sep 2007
    171
    i just want to intercept the wiring before it hits the amp rather than after it. so i'd be disconnecting the inputs to the amp and patching it to an RCA into the amp
    thanks for that btw
    Sep 2007
    171
    Oh how silly of me... the amp's been staring me in the face the whole time... It's right behind the stock subwoofer.
    Does anyone know the pin in/outs of either the amp itself or the wiring harness shown on the right of the picture?
    JohnS3's Avatar
    Oct 2004
    3,021
    Have a search around in the ICE section. There's a chap called andymac who should be able to help you out.
    Sep 2007
    171
    In answer to my own question, here is the (very limited) pin diagrams for the wiring harness leading into the non-boss amp in the subwoofer enclosure... colours are just what i saw in mine and may differ.
    1 yellow - RIGHT LINE LEVEL
    2 purple - GROUND/COMMON LINE LEVEL
    3 green - LEFT LINE LEVEL
    5 orange
    6 orange/purple
    7
    9 white
    10
    11
    12
    13
    14
    15
    16
    17 yellow/red (speaker out)
    18 yellow/brown (speaker out)
    19
    20 black/white (speaker out)
    21 black/blue (speaker out)
    22 brown (power)
    23 red/blue (power)
    Hope this helps someone for future reference.
    I have now rewired my amps to run off the line level output of the RNS-E and the sound is a million times better than running off the speaker to line level converters.
    Jan 2014
    Hi, do all a3 8p have this amp and sub in the boot? mine is a 2010 sport back , its not the bose upgrade.
    I want to install an active sub and need the low level input.
    cheers Ash
    Jan 2014
    69
    the rear amp is in the sub box of the blakput systems isn't it?
    Jan 2014
    cheers I found it, behind all the carpet in boot lhs
