AH FabricationsChris Nott
Results 1 to 7 of 7
    RC
    23
    Front ashtray trim removal
    Might sound a little stupid, but can anyone advise on how to remove the front ashtray trim?
    Changing that piano black to the brushed aluminium!!
    Cheers,
    R
    Low life livin' the high life.
    Feb 2008
    1,638
    Finally went for the brushed aluminium then did you! How much did the kit cost? 300 big ones?
    I've decided to keep piano black in the middle but i'm looking for ali door trim to mix it up a bit!
    As far as removal goes.... Don't be shy and simply pull it. I've just removed the gearstick surround to fit a new gearknob and i was a bit worried about breaking clips. They're not flimsy things and they snap solidly in and out. I didn't remove the ashtray but if you look at my thread further down titled 'New gearknob and gator'....someone in there has posted how to do it.
    Paul.
    A3 2.0T FSI Quattro S-Line, 3 Door, Avus Silver (special ed.)
    For Sale:
    S-Line gear knob, stick and gator.
    Full set of OEM wheel bolts (incl. locking nuts & caps)
    19" BBS CK's Anthracite - SOLD
    Boydie
    The ash tray trim is difficult and i did end up scratching it in two places but lucky its at the back and is not visible!
    Basically, you need two thin flat head screw drivers and you have to pry the trim off as it is clipped in tight
    When you get it off, make sure you make note on how it is positioned because when i went to put the new trim on, the edges didnt meet up properly and I still clicked in place which meant i had to take it apart again and thats where i scratched it
    RC
    23
    Thanks guys!
    The ali trim was 312 delivered!!
    Looks good though!!
    R
    Boydie
    holy foooooooook!
    I paid 100 on ebay for mine
    Kontraband's Avatar
    Dec 2007
    1,998
    Quote Originally Posted by Boydie View Post
    holy foooooooook!
    ahahaha rub it in Boydie!
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    I paid 280 delivered from vagparts, remember to mention your an audi sport member
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
