Sky InsuranceBadger5
Results 1 to 14 of 14
    Rafkoo's Avatar
    Feb 2008
    S London
    64
    Key works.. sometimes...
    Having owned my 3.2Q for a few weeks now I have noticed a curious "fault" when I sometimes go to unlock the car... the remote key does not unlock it...!
    This has maybe happend on 5 occasions in 3-4 weeks of ownership (1 in 10 times maybe), but basically, the car does not respond to the key to unlock doors or boot - and I have to manually turn the key in the door to get in. It starts the car no problem everytime, and always locks the car at the end of the journey...
    Has anyone else come across this? Could this be a battery issue with the key?
    Raf
    A3 3.2Q Sport DSG
    "Knowledge is power, tuning knowledge is horse power"
    Jan 2007
    Chelmsford, Essex
    456
    I would change the battery first. Had a key module changed as it would drain a new battery in two months.
    windsurfer
    Nov 2006
    London, Porto
    1,327
    battery.... try it before anything else. But does the red LED in the key flashes when you press the button?
    Pedro
    FOR SALE: S3 Phantom Black, left hand drive, Xenons, FBMFSW, bucket seats, BOSE, rear parking sensors, armrest, interior light package, Symphony II+. Full Audi service history and 4 new Michelin Pilot Sport 2. 18500 miles PM for details! I want to give it away have a good family reason. For a quick sale around 19.5k PM only if interest is genuine! Thanks
    Jan 2005
    cambs uk
    1,139
    LED? Mine don't have LED's on them
    Mine do the odd thing with the double tap timing not working properly but never had this, very strange
    reubs1981's Avatar
    Yellow peril
    Manchester
    52
    I had this issue only once. One morning neither remote would work and I had to get in the car manually.
    I'd noticed a few days earlier that the clock kept resetting itself and starting again from midnight. I went under the bonnet, lifted the plastic cover from the battery and saw a loose connection (can't remember if it was + or -). I had been a good samaritan and started a lady's car with my jumpleads some weeks before. Evidently the wire had worked itself loose.
    Might be worth having a quick look under the bonnet if you've had similar symptoms before replacing battery/module, etc.
    2007/07 A3 Sportback 1.9TDi SE in Toucan Yellow and now debadged because my '.' fell off!
    Rafkoo's Avatar
    Feb 2008
    S London
    64
    Thanks everyone - I'll try the battery first and take it from there.
    Raf
    A3 3.2Q Sport DSG
    windsurfer
    Nov 2006
    London, Porto
    1,327
    there is a little red led that flashes on my key... I don't have it with me but pretty sure it has...
    Pedro
    Jan 2005
    cambs uk
    1,139
    checked both of mine and there's no LED Perhaps its a newer thing?
    windsurfer
    Nov 2006
    London, Porto
    1,327
    well mate my car is in Portugal with my keys I will check again this weekend but I am pretty sure when I press a button there is a red LED on the key...
    Pedro
    Rafkoo's Avatar
    Feb 2008
    S London
    64
    Mine don't have an LED.
    A3 3.2Q Sport DSG
    windsurfer
    Nov 2006
    London, Porto
    1,327
    Just to confirm... there is a red LED in the key, if I press a button the light flashes... It is in the same end as the button to open the key when it is retracted....
    Pedro
    Jan 2005
    cambs uk
    1,139
    must be a new thing then as neither of mine have this
    interestingly though, i managed to get the car all confused today
    Spend the weekend in Rochester so fo a change I locked the car, came out this morning loaded up with bags, pressed the button twice, went to open the rear doors, nothing, quite normal as mine is overly sensitive to the time lag between button presses so doesnt always open all doors on a double press
    Anyway, got quite hacked off, so pressed the button about 20-30 times, then nothing
    doors wouldn't lock or unlock, even with the key in the door!
    After about 30 minutes all was ok though, i like it when things fix themselves
    Nov 2006
    74
    Haha I had this once, I stormed off after parking up because someone stole my space but then the key would not lock. I am pressing it loads, no luck so I use the key in door and again no luck.
    About to be late and it won't lock after 5 minutes it started working again and not had the problem since.
    windsurfer
    Nov 2006
    London, Porto
    1,327
    who said... german cars are not temperamental? lololol
    Pedro
