Monster MotorsportEM Tuning
Results 1 to 13 of 13
    Low life livin' the high life.
    Feb 2008
    1,638
    How to change the gear knob/stick & gator.
    Alright chaps...
    I'm going to be changing over the standard s-line gear knob tomorrow and swapping it for the solid brushed alloy one. Should be a nice addition.
    Anyway i haven't even tried removing the old one yet obviously because if it doesn't go as smoothly as i anticipate i still have to drive the car!
    So, has anyone done this? Is there anything i need? Do i have to remove the whole of the gearstick surrounding trim to release it or what?
    Just trying to avoid any schoolboy errors!
    Thanks in advance.
    Paul.
    A3 2.0T FSI Quattro S-Line, 3 Door, Avus Silver (special ed.)
    For Sale:
    S-Line gear knob, stick and gator.
    Full set of OEM wheel bolts (incl. locking nuts & caps)
    19" BBS CK's Anthracite - SOLD
    Paul
    Here is a PDF from the workshop manual which may help...
    gear selector cover .pdf
    If you need anything else let me know.
    Dave R (h5djr)
    Feb 2008
    1,638
    Quote Originally Posted by h5djr View Post
    Paul
    Cheers for that Dave, top man.
    The only thing is, sometimes workshop manuals don't give the full story! For example the manual might say to simply remove A, push down B, insert C and job done! Other than the pliers it doesn't suggest any other tools or if there's risk of snapping any clips etc.
    For Sale:
    Yes that's true. A dealer will often have a box full of all types of clips etc so if the technician does brake one it's no real problem. Sometimes the workshop manual does give a warning that a clip for example is very easy to break when it's removed or that a new one should always be fitted, but nothing in this case as far as I can see, apart from the clip on the bottom of the actual gear stick which I think it says you have to break off and replace with a new one.
    The manual is also aimed at technicians who have already done some basic courses with Audi.
    Dave R (h5djr)
    L60N
    Sort of on topic, but how do you straighten up a gear knob? Mines a bit on the piss :P
    regards
    Feb 2008
    1,638
    I would imagine it's a case of literally just twisting it!
    For Sale:
    L60N
    I did try that, but no give, so i gave it a bit more pressure, but stopped as i thought "this is gonna break" :P
    Feb 2008
    1,638
    Quote Originally Posted by L60N View Post
    Have you looked at the PDF file that Dave posted above ^?
    The answer is probably in there. I think i'm right in saying you have to screw the stick on at the base and then secure it with a permanent clip. I.e. if yours is on the piss it would involve taking off all the surrounding trim, lifting up the gator and adjusting it at the bottom. Sounds like a ball-ache to me!!
    Paul.
    For Sale:
    Feb 2008
    1,638
    By the way.... Am i right in thinking Audi make EVERYTHING impossible to change yourself and twice as expensive by interlinking components e.g. you can't just change the gear knob, you have to change the whole job lot and to do that you have to dismantle half the car. I mean for f**k sake!
    For Sale:
    Boydie
    its simple
    Open your ash tray
    Pull the trim around the gear stick and pull at the front - this will easily remove the trim.
    Bring the trim up over the gear knob - basically turn it inside out
    There is a clip wraped round the shaft of the gear knob - this can be pried off easily and hey presto, the gear knob is off
    unfortunately you need a special tool to put the clip back on therefore mine doesnt have it attached but it is impossible for the knob to spin on the gear stick
    this could be solved by using a cable tie or going to your dealer and get them to attach it but i wouldnt worry
    Jul 2012
    Sandhurst
    95
    Quote Originally Posted by Boydie View Post
    its simple
    Open your ash tray
    any idea if the tt screw on knob will fit an a3 sline 07 8p model? If not how can I get it to fit?
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Quote Originally Posted by Dan Hobley View Post
    Hi Dan, yes it will fit mate. I have a TT mk2 knob for sale in mint condition if interested mate? Send me a PM if you are.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Miss read the post mate, sorry not sure if the screw one will go, but definately the pull off one will fit.
    Sorry again if i have given wrong info.
