JMB RetrofitsVolks Autos
Thread: Programming key
    Mar 2008
    Programming key
    I recently purchased a 2005 A3 but only got one key. I have bought a replacement key and got a blade cut. I want to program the remote so that it can open the doors / switch off the alarm. (I realise that I will need to get it coded to the immobiliser to drive the car)
    I have followed the instructions below which a member of the forum kindly gave me but the car doesnt respond!
    I currently only have one fully functional remote and an identical one which I am trying to program.
    Any help appreciated
    Instructions I have followed
    1. Take a spare key and insert it into the ignition. Turn it one click forward.
    2. Roll down your window just in case. Step outside the car, and lock the car with a second key.
    3. With your second key fob press the unlock button. The lights should flash.
    4. Now lock the car with the key fob, and then unlock it.
    5. Remove the key from the lock and the key from the ignition, and try it's function
    JohnS3's Avatar
    Oct 2004
    3,021
    Have a read here, hope this helps.
    Mar 2008
    Quote Originally Posted by JohnS3 View Post
    Thanks, that link was useful with info about the immobiliser
    Does anyone know if it is possible to programme a key fob to just open the doors remotely
    (I now realise I wont be able to use it to start the car without obtaining the SKC.)
