Results 1 to 16 of 16
    Dec 2007
    52
    Suspected gearbox problem - 1.6 tiptronic
    Hi all,
    Wondering if you could help out. I am wondering is my gearbox has a problem. Here's why:
    - when I change gears from P to D, relatively quickly, there's delay in engagement and a clunk sound when engaging (didn't happen with any of my previous cars), or if I change from R to D, same thing. If I change slowly, it seems to engage a lot quieter but still a slight delay
    - when I am driving on the highway, in 6th gear, and accelerate quickly after slowing down, there's a jerk from the gears changing (6th to 4th), this hasn't only happened once. I've noticed it happening more often now and wondering what's going on.
    I've reading other articles that some of those symptoms mean it's a bad gearbox and needs to be fixed etc.
    Anyone heard or experienced these things?
    Thanks in advance.
    Dec 2007
    52
    Anyone?
    Dec 2007
    52
    Anyone?
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    'Clunking' was part and parcel of my DSG (now called s-tronic) experience.
    Hard to comment on yours specifically though.
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Dec 2007
    52
    Thanks Bowfer, I am hoping that nothing's wrong, my car's only got 24000km's on the clock!
    From my experience, no other car has done this. This is my first "tiptronic" though.
    Even with that in mind, I am sure it can't be any different from a normal auto tranny.
    Does anyone have experience of fault codes showing up when there's something wrong with the gearbox?
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by katsumoto View Post
    The way it's built and works is vastly different from a normal auto box.
    I became convinced, quite early on, that my DSG was strange.
    However, driving other DSG cars proved it wasn't.
    You will, at some point, get some 'clunking', simple as that.
    I used to get occasional clunking when changing from 2nd to 3rd.
    I used to get clunking when trying to pull away on a steep hill.
    I used to get clunking when going from reverse to forward.
    When I say 'clunking' I mean some quite unpleasant driveline shunt, occasionally accompanied with a loud(ish) bang.
    Unpleasant enough for passengers to go "ouch", or make comment about my driving, when all I was doing was pressing the bloody throttle!
    DSG did, sometimes, make you look like a learner with poor clutch control.
    Not all the time though.
    If yours is doing it all the time, get it checked.
    If it's only occasional, I'd say you're fine.
    Dec 2007
    52
    From the things that you have described, my experiences seem pretty similar. Good to hear that someone has had similar "problems". I'll keep my eyes and ears open for any further "developments". Let's hope it's all nothing but paranoia!
    Thanks for the info Bowfer!
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Ssssh, you're not allowed to call them 'problems' on here.
    It's you not adapting your driving properly.
    I'll get me coat.
    Dec 2007
    52
    haha, right on! that's exactly what the stealers would say! it's your fault, not ours!
    dbm
    dbm's Avatar
    Preston, Lancs
    518
    I've had issues with my DSG in the past, which may or may not have been caused by my driving style, but ultimately needed a new ECU to fix (done under warranty at 55k miles).
    As Bowfer says, DSG is a totally different type of 'box to a traditional auto. DSG has two clutches whilst regular autos have no clutch but a torque converter instead.
    The 'Audi approved' way to drive the DSG seems to be to have it in some kind of gear (D,S or Tiptronic) pretty much all the time, except when you are stationary and want to take your foot of the brake. If you stick to that approach it should snatch a lot less...
    Cheers,
    Dan
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by dbm View Post
    Sorry, but I don't follow the above.
    How else are you going to drive it, unless it's in D,S or tiptronic?
    dbm
    dbm's Avatar
    Preston, Lancs
    518
    I used to knock the box into N when cruising to a stop at lights for example, and would flick between N and D if I was in stop-start traffic. Both of these behaviors seemed to exacerbate the problem.
    Cheers,
    Dan
    Dec 2007
    52
    hmm, I guess I drive the Audi approved way then. I used to think (my old car) by setting it to N while cruising would save gas, until I read that it actually doesn't because the engine then has to use more gas to keep it running....gotta try find that article again
    But also, mines not a DSG, it's a tiptronic....any differences?
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Oh, I assumed you meant S-tronic, which was called DSG.
    I think tiptronic is different.
    God knows.
    DSG, s-tronic,tiptronic,technotronic,pump up the jam, pump it up.
    Dec 2007
    52
    cheers to that! all the labels and probably the only differences are the colors of the cables....
    Aug 2007
    439
    Yeh, a bit like fridges and cookers really - they both use electricity, so they're probably much the same......
    A3 2.0TDI Sportback S Line 184 Quattro S-Tronic, Mar. 2014 Glacier white. Electric seats, sunroof, se suspension, heated folding mirrors, Reversing camera, Nappa leather, TPMS, Hold assist, Xenon plus adaptive lights with variable active range control, lane assist, Interior light pack, Technology pack, Comfort pack with ACC, park assist & parking system plus
