Volks AutosAH Fabrications
Thread: Door Seal
    Jul 2007
    10
    Door Seal
    The seal on the car body rather than the actual door has worn through by rubbing on leaving the car , Does anyone know how easy it is to replace , ie how to remove the plastic surrounding the seal on the inside of the vehicle .
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    its easy, you can get the rubber off and replace it by just pushing it under the trim, don't remove the trim unless you need to, its a pain to do.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
