Monster MotorsportEM Tuning
Results 1 to 16 of 16
    Apr 2006
    england
    754
    votex rear skirt help!!!
    can some tell me if you need to remove the original rear skirt before you can put on the votex one or does it just glue over the orignal one??? also is there screws, brakets to stick it on?? also to today i got my votex front spoiler i believe its a glue on thing but there is few holes for screws does it has to get screwed on too??
    Apr 2006
    england
    754
    any help pls
    Boydie
    What year is your car? By the sounds of your description you may already have the sline rear splitter :S
    The front bonds onto the front bumper along with two screw brackets under neath - I didnt get these with mine as mine was salvaged but i made makeshift ones!
    Apr 2006
    england
    754
    its a 54 plate
    Boydie
    what does that mean? I am from northern ireland and we do not use that system
    Apr 2006
    england
    754
    meaning its a 2004 year model
    Boydie
    ok - so, the 2004 does not come with a standard skirt
    also, what is the part number for your votex skirt? the 5 door version will not fit a 3 door or vice versa
    i think the 3dr one is 8P007""""" from memory but could be totally wrong :S I have a couple of threads i think about it if you hit the search button
    It should be a straight fit with bonder and screws - I chose not to bother with the votex rear splitter as I did not like it :S you might be btter off sourcing a 2006/7 rear bumper which has had a facelift and splitter
    Apr 2006
    england
    754
    ok check this out this has all the part numbers you would ever need
    http://www.audi.co.uk/etc/medialib/c....0005.File.pdf
    Boydie
    if you have the skirt - the part number will be on it!
    Apr 2006
    england
    754
    i wanted to know if i get the rear bumber skirt the votex one if it is just i glue on thing or do i need some brakets to hold it in place
    Boydie
    If you get your votex rear splitter from audi, it will come with the correct braketry and instructions
    Also, if you order from audi, they will ask you your chassis number so you will get the correct splitter
    Mar 2008
    Ne Scotland
    13
    can you still purchase the kit or parts of it direct from audi? as I am struggling to fine the front splitter on ebay etc.
    Boydie
    Took me ages to track one down on ebay and it was a damaged one!
    Havent seen the for sale on ebay since to be honest! (a year nearly)
    Mar 2008
    Ne Scotland
    13
    have seen 2 but not been able to get on to put last minute bid in and mt max bid has just been 2 low both times.
    petewon's Avatar
    Dec 2004
    Newcastle
    514
    Quote Originally Posted by khalil View Post
    No the original skirt should come off, its a pian in the arse to get off too. Its possibly easier to remove the whole rear bumper clip the bottom bit off then clip the new one on and refit the bumper. As boydie says make sure you get the correct one as theres a few and they dont all fit between the two 8P shapes.
    Pete
    _______________________
    8P A3 2.0 FSI Sport, Leather/Alcantara, Bose, Xenons.
    petewon's Avatar
    Dec 2004
    Newcastle
    514
    Quote Originally Posted by westtra View Post
    The ABT ones not too bad, Ive bought from this seller before and his prices are canny http://cgi.ebay.de/Abt-Frontspoilerl...QQcmdZViewItem
    Pete
