Badger5Monster Motorsport
Results 1 to 9 of 9
    Oli.'s Avatar
    551
    S3 19" wheel upgrade pressure's
    When upgrading to 19" wheels on the S3, what pressures are you running?
    My wheels should be here tomorrow, and I want them ready, as I collect my car next tuesday, and then Im straight off on a 400 mile roadtrip!!
    www.bmvs-camperhire.co.uk VW California hire and sales
    RWD sucks!
    Dec 2007
    175
    I am using 5 psi more than the recommended pressure on each axle for 2 persons. I found it good balance between handling and pothole protection.
    si_reading's Avatar
    May 2007
    Cheshire, UK
    168
    Mines not an S3 but I tend to run around 32psi front and back my 19's.
    Si
    2009-Current | Porsche Boxster 2.7
    2007-2009 | Audi A3 2.0 TDI 170 S-Line
    2005-2007 | Audi A3 1.6FSI Sport
    maars's Avatar
    Full speed ahead
    May 2007
    567
    My tyre fitter recommended 34psi front & rear.
    Daytona RS4 Avant :: black optics
    Oli.'s Avatar
    551
    Quote Originally Posted by DemianM View Post
    So what actual pressures are you running? Havent got the car yet, so cant consult the manual.....
    L60N
    Depends on the rim width and wall size you plonker. lol
    Oli.'s Avatar
    551
    Who you calling a plonker?? Those who have fitted 19" wheels, that my question is aimed at, will know tyre size rim width etc ie 235/35/19, on a 8.5 x 19 rim - So if you havent got anything constructive to say, dont say anything - As you dont have bigger wheels on your S3 you are hardly in a position to comment .........
    RWD sucks!
    Dec 2007
    175
    Right now it is 40 psi front, 36 on the back. Front is almost same as OEM recommended (39) and back is 4 psi above recommended. Nice balance, a bit on the oversteer side on the track, I like it. You can lower the pressure a little on the back if you feel the ride too harsh (you sure will LOL)
    Oli.'s Avatar
    551
    Thanks mate - Someone with a sensible answer
