Chris NottVolks Autos
Results 1 to 21 of 21
    Oct 2003
    up north...
    767
    msfw retrofit slipring and controllers
    i've surfed trying to find the answer but cant - if i was upgrading a dsg car without mfsw to mfsw, do i need an upgraded steering wheel controller or slipring?
    etka tells me that for the elecronics modules are:
    8p0 953 539 H, F, AH, A, G or J - i know F works but what about the others
    and does dsg automatically work with mfsw, and does cruise always work with mfsw
    sliprings are:
    1k0 959 653, D, A or C
    afaik, D works with mfsw and dsg (its the only one available for 2008 cars) but what about the other ones?
    thanks for any info
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,117
    Get in touch with 'mattandrew', he has just carried out this mod!! We swapped over my MFSW to his non MFSW and yes we both have DSG I have a flat bottom now also, which is nice
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    I have just fitted cruise and a MFSW to my 2004 DSG A3
    Cruise would have worked with my existing ECU 8P0 953 549 and slip ring 1K0 959 653 but i also wanted to fit the MFSW.
    After looking into this to fit a mfsw I had to upgrade the ECU to 8P0 953 549 F and the slip ring to 1K0 959 653 D
    Sorry i dont know about other versions
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,117
    I told you Matt would be along! Hope that answers your questions Dunk
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,371
    Does anybody know if a 1K0 959 653 C slipring would work with FBSW for a 53 plate that comes with a : 1K0 953 549 A ?
    Fossie
    Rhubarb Triangle
    3,961
    This will give you all the answers :-
    Steering Wheel Control Module Versions - Ross-Tech Wiki
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,077
    Hi Dunk,
    I retrofitted, a MFSW and cruise to a blokes car the other day. His car was an A3 2.0TDI DSG 2005 55 plate. I originally thought that he may need a new slipring and steering ECU, but then i thought, as he already had the DSG functions on his non MFSW that it should accept the MFSW no problem, as i believe, some one correct me if i am wrong, if you have DSG, then you should already have the highline steering ECU!
    Anyhow, i decided to try it anyway, and guess what, if worked fine after coding in VCDS. also the advatage of moding from a non MFSW with DSG to MFSW with DSG is that you also have the correct wiring harnes for the airbag, so no need to go and spend that hard earned cash on an adapter that is not needed.
    Hope this is of help fella
    Danny
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Digzz's Avatar
    Jan 2009
    London
    1,371
    Thanks....
    It states that my old module is type 1 and 1K0 959 653 C is type 2 as below :
    Does this mean I need the type 2 and this is the correct one ?
    Type 1: 1K0-959-653 and 1K0-959-653-A
    Type 2: 1K0-959-653-C and 1K0-959-653-D
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by digzz View Post
    Thanks....
    The difference between type 1 and type 2 is that the type 2 has the steering position sensor in the slip ring and the type 1 doesn't.
    Are you talking about fbmfsw or fbsw ?
    Also it depends on what airbag system your car has. Is it single or dual stage ? You cannot mix the two.
    Digzz's Avatar
    Jan 2009
    London
    1,371
    Yes I'm want to install the FBMFSW.
    I think it's single stage .....as I have the big old steering wheel as it was the first one's fitted to the first audi a3's ..
    Fossie
    Rhubarb Triangle
    3,961
    You need a 'highline' steering module to work a mfsw. Your version 'A' is midline and is not compatible with a mf wheel.
    A bigger problem is that if you have single stage airbags then the airbag control module will not operate a two stage airbag. Some people have fiddled around and wired the connectors together but there is no guarantee it would work if and when required !!!
    Digzz's Avatar
    Jan 2009
    London
    1,371
    Ok thanks......So what slip ring do I need ?
    Fossie
    Rhubarb Triangle
    3,961
    I would say Type 2 with a highline steering module. What year is the fbmfsw ?
    Digzz's Avatar
    Jan 2009
    London
    1,371
    I haven't bought it yet ......Starting to buy the little bits first..... So the Slip Ring 1K0 959 653 C should be OK ? or is it only compatible with only a certain fbmfsw ?
    Fossie
    Rhubarb Triangle
    3,961
    Sorry mate - I think you may be missing the point.
    Unless you can buy a fbmfsw with a single stage airbag (I don't know if there is such a thing) then your car safety system will not support the wheel that you are planning to fit. It isn't just the drivers airbag that is single stage in your car, it is all the other airbags as well. It would mean that you would be mixing airbag systems and using a single stage control module !
    The wiring loom and connectors are also different on the fb wheel.
    To answer your question then yes the C version would be ok but only with a suitable steering module.
    Digzz's Avatar
    Jan 2009
    London
    1,371
    OK....Do you know if there is anybody else on ASN has done this type of upgrade from an old 8p like mine ? surely somebody has come up with a way to make it work
    26,776
    The 2 different slip rings are 1 is supporting everything & other doesnt, the steering ANGLE sensor is connected to both types on 8P's from 03-09, from 09 they started to switch to the newer K steering cu & steering angle sensor didnt exist anymore & got the reading from the rack, they still use the same slip ring on 8P's.
    I can supply the correct slip ring.
    Only way to make the airbag 100% work is to fit a dual stage system.
    Digzz's Avatar
    Jan 2009
    London
    1,371
    [QUOTE=NHN;1320157] I can supply the correct slip ring.
    I've just bought an 1K0 959 653 C . Just starting slowly to collect the bits....then I'll head down to u in 2 months time....or so...
    26,776
    TBH your best bet would of been the D slip ring, of which I have
    Digzz's Avatar
    Jan 2009
    London
    1,371
    Ok hold that for me.....I only bought this one because it was £20 ...one question why do u think D would be better?
    26,776
    Cause D is matched as the known daddy to allow all to work.
