AH FabricationsVolks Autos
Results 1 to 10 of 10
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    MFSW issues - Help needed on programming
    Vehicle and options
    Audi A3 2004
    Concert head unit
    Audi navigation – the one which comes up in the DIS and controls in the centre console
    MFSW – out of a 2008 sline with scroll wheels
    Audi bluetooth phone prep
    DSG
    DIS
    Cruise
    Problems
    The right scroll wheel controls the volume OK
    The right button works the bluetooth OK
    The MODE button works the phone prep
    BUT the left scroll wheel does not skip to the next track when palying a CD
    I know there are limited functions available but I believe it should skip the track
    I have the following coding:
    16 – Steering wheel 0013142
    77 – Telephone 0011422
    56 – Radio 0000231
    Is there any other coding which should be done or I have got wrong, can’t find much info on 56 – Radio so this could need changing
    Thanks in advance
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
    GeoffT's Avatar
    Aug 2007
    Exmouth
    267
    Quote Originally Posted by mattandrew
    Vehicle and options
    Audi A3 2004
    Concert head unit
    DSG
    DIS
    Cruise
    Problems
    56 – Radio 0000231
    Thanks in advance
    Which version of concert Head unit is it? If it is a Concert II I think you need to add 4 to the last digit to add MFSW. ie code it 0000235 in your case.
    A3 Sportback Sport 2.0 TDI 140 Mauritius Blue, Black/Grey matrix, GSM prep in armrest, MFSW, 17" 16 spoke wheels, Acoustic Parking rear, Cruise, Non-smoking pack, Symphony II+
    mattandrew's Avatar
    Sep 2007
    971
    how do I check the version? If I change the last letter will that not alter something else?
    Previous
    S
    Ibis White - 2007
    Current
    S3 Black - 2001
    VCDS user
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Matt,
    You need to add 2 to channel 7 coding of the radio enable CAN based Multi-function steering wheel support.
    More info here if you need it.
    Hope that helps.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    GeoffT's Avatar
    Aug 2007
    Exmouth
    267
    Actually Matt, having re-read your post I'm confused. You say you have Concert headunit AND Audi Navigation. You can only have one or the other surely? If you have the Audi NAVplus (RNS-E) navigation, marms is correct, if you have a concert II head unit my suggestion is correct.
    mattandrew's Avatar
    Sep 2007
    971
    Just checked it the concert II
    I have tried in 56 - Radio 0000235 but no joy
    Previous
    S
    Ibis White - 2007
    Current
    S3 Black - 2001
    VCDS user
    mattandrew's Avatar
    Sep 2007
    971
    Quote Originally Posted by GeoffT
    I have the concert II and the Audi Navigation System with single colour display, its the simple version which displays in the DIS.
    I gona have a look at marms post now
    Previous
    S
    Ibis White - 2007
    Current
    S3 Black - 2001
    VCDS user
    GeoffT's Avatar
    Aug 2007
    Exmouth
    267
    Matt, check this out. This should apply to your Concert II.
    http://wiki.ross-tech.com/index.php/..._%288P_only%29
    mattandrew's Avatar
    Sep 2007
    971
    Thanks GeoffT I have already tried that I coded it as 0000235 but no joy
    Maybe the scroll is not compatible with my concert II
    Previous
    S
    Ibis White - 2007
    Current
    S3 Black - 2001
    VCDS user
    mattandrew's Avatar
    Sep 2007
    971
    Quote Originally Posted by marms
    Matt,
    Hope that helps.
    Thanks for that but channel 7 is not available in the radio, and when reading the link that is for the navigation which is working ok.
    Ill get there in the end
    Previous
    S
    Ibis White - 2007
    Current
    S3 Black - 2001
    VCDS user
