Chris NottEM Tuning
Results 1 to 26 of 26
    Kontraband's Avatar
    Dec 2007
    1,998
    Educate my salesman
    My cars nearly here, finally, and I want to check I've got everything I need sorted. Ive mentioned some things to my sales guy and he's been a little unaware....
    From reading on here, I understand I can have these wants. Am I correct?
    1. The dashboard lights only to be on when the lights are (I have auto lights)
    2. The emergency hazards to fire up on emergency brakes
    Is there anything else over what normally falls out the dealerships that I might be interested in tweeking?? Or can someone point me in the direction of tweeks?!
    TIA.
    boggysv's Avatar
    Nov 2007
    572
    Sales guys sometimes wont know about those stuff. Even though they sell cars for a living
    1) it's might just be a job for them, not a passion
    2) there are too many models, and they cant know all
    Try to speak to a techie on your visits to the dealership, or invest in your own vag-com.
    World's Fastest S3 Driver - racing old people in toyota camries since 1997 with a 97.6% winning rate.
    Dec 2006
    Ireland
    2,538
    1 - yes
    Select 17 (Instruments)
    Coding -> Function 07
    The last digit controls the instrument lighting when the exterior lights are off.
    Mine has just needles lit (which I think is a 7). You can change the values from 0 to 9. I think 0-4 is for US and 5-9 EU.
    The options are (I think) :
    0/5 No Lighting
    1/6 Back Lighting
    2/7 Needles
    3/8 Both
    4/9 ?
    2 - yes
    Select 09 (Central Electronics)
    Long Coding -> Function 07
    Byte 17 Bit 0 Emergency Brake Flash Light active
    Check this post for more bits and bobs that can be enabled by VAG-COM.
    Kontraband's Avatar
    Dec 2007
    1,998
    Boggysv - yeah, I understand that sometimes they won't know all the in's and out's of every audi...
    hence why I just wanted to be sure before I speak to him telling him I can do something that he might not know. I have what I believe to be a very good relationship with the sales guy, but as you say, they dont always know everything. Thanks for the suggestions tho.
    The dashboard illumination is normally only on when you're main lights are on. I had mine changed so that they are on all time. This used to be the case with all my previous A3s.
    You may want to decide which type of remote central locking you want. The standard is one press to open the drivers door only and a double press to open all doors. I had mine changed to a single press to open all doors. Also automatic locking at 15mph is standard but can be deactivated if you want.
    These were the only 're-coding' I asked my dealer to do before delivery.
    Remember the dealer does not use VAG-COM to look at these codes. The use the much more sophisticated VAG 5051 Computer Diagnostic System which is only available to dealers. The codes may well be the same but to be on the safe side just tell them what you want rather than just giving them code details. From what I've seen when a technician was doing some changes on my car it has a more detailed menu system than VAG-COM.
    Dave R (h5djr)
    Kontraband's Avatar
    Dec 2007
    1,998
    Mark/Dave, many thanks... thats pretty much exactly what Im after...
    Apr 2006
    571
    Quote Originally Posted by h5djr
    That's useful to know.
    I find it a pain when you drive through a heavily shadowed road, and the lights don't come on. You are left with dark unreadable dials.
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by mfspen
    The needles, however, are always lit.
    Some evening you are bored, park up in a dark spot, turn off your lights, and then turn up the illumination on your instrument cluster to the maximum. The red light from the needles casts a rather nice glow across the numbers to either side of the needle. I'd like to have my instrument cluster set up like that, except for the fact that all the other backlighting on the various buttons and the AirCon are also at maximum illumination which makes it all too bright.
    I'll try to post a photo to show what I mean for those of you who don't get bored of an evening!
    Dec 2006
    Ireland
    2,538
    I knew it wasn't VAG-COM they used, but just added the codes for reference in case any other members wanted to do it themselves.
    Kontraband's Avatar
    Dec 2007
    1,998
    or havent got their cars yet?
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    The only one that they may not set for you is the audible confirmation of alarm set and un-set.
    I've heard talk of EU rules regarding noise polution.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    Kontraband's Avatar
    Dec 2007
    1,998
    yeah, I'd heard mention of that too...
    Dec 2006
    Ireland
    2,538
    yeah, but sure you can bribe somebody that has VAG-COM with some beer tokens and they'll do it for you.
    Kontraband's Avatar
    Dec 2007
    1,998
    heh heh, yeah... its been tenatively discussed...
    The world should operate on the currency of beer... it would be a good place...
    though Id probably be skint... so maybe not?!
    Aug 2004
    An der sud Koste
    711
    My pod was lit constantly by default and is the way I prefer it, looks much better. It does of course go off if it gets dark to remind you to put your lights on. However I tend to leave the lights on Auto so pod is illumintaed all the time.
    Sportback
    Kontraband's Avatar
    Dec 2007
    1,998
    eh? So if the dash is lit up all the time, the only time it goes off is if its dark and you dont have your lights on??
    Yes that's it. The go off when it's getting dark and your main lights are not on to remind you to put your lights on.
    Dave R (h5djr)
    JohnS3's Avatar
    Oct 2004
    3,021
    Why not buy your own VAS 5051? There's one on eBay, it's a little pricey though.....
    Kontraband's Avatar
    Dec 2007
    1,998
    Quote Originally Posted by JohnS3
    yeah, just a bit... I have no where near that amount of beer in my garage!
    The one eBay is a VAS 5052, the portable version. The VAS 5051 is mounted on it's own trolley. If that's the price of the 5052 I wonder how much the 5051 costs. Probably as much as the car!
    Dave R (h5djr)
    Sep 2006
    383
    Educate my salesman
    Basically kick him in the bo--ocks, saves all the later frustration
    Kontraband's Avatar
    Dec 2007
    1,998
    hahaha, wait.. he's cool... I dont need to kick him in the balls yet..
    Ive heard other comments though about the service department!
    Jan 2005
    cambs uk
    1,139
    LOL - just read this thread
    Easier to solve world peace than educate any audi dealer!!
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    world peace... ive heard of that
    educated audi salesman... pretty sure this is a myth
    On Boost
    Manchester
    1,756
    My dials are off when the lights are off, but my needles are on ( a nice white glow ) also as a rule i tend to drive using the digital speedo as my main source of speed reading! anybody else use the digital speedo as there speedo?
    p
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by phantom
    yup. i find it easier to read. takes a bit of getting used to when you drive a car that doesn't have the digital speedo. I keep looking to the middle of the dials for it!
