Monster MotorsportBadger5
Results 1 to 11 of 11
    Feb 2008
    25
    Exclamation PCD + Offset for 8P Chassis + Lowering 40mm
    Hi,
    Not a A3 owner yet unfortunatly.
    Looking into buying a 8P A3, 2003 plate.
    Wanting to put 18" RS6 reps on it
    What PCD and offset are perfect fit for it, and would lowering 40mm be possible.
    Cheers.
    RWD sucks!
    Dec 2007
    175
    5x112
    8" width
    50 or higher ET
    With a 40 mm drop, any lower ET May rub if you use a square-should tire. That is to be on the safe side and have no rubbing even with passengers. You can always remove the rear fenderliners screw and that will give a little more clearance.
    hope this helps!
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    5x112 and ET42-50 will fit, get a higher offset and spacers to complete the look
    Feb 2008
    25
    well tbh i wanna slam the A3 as low as possible to the floor on 18s without effecting anything. my corsa was quite low, i had it front/rear 75/120mm
    ok so 5x112, 8" width, and if i got ET50 i could drop 40mm with no problems?
    Will it effect the camber at all or is it a fixed camber on the A3
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    40mm isn't slammed. Boydies is at 40mm and his is fine.
    Feb 2008
    25
    no but, my corsa was down 75/120 thats slammed
    Oct 2003
    up north...
    767
    8" 45 offset might catch slightly if you lower a lot, depending on the tyre -
    this wheel sticks out 17mm more than oem
    its difficult to get wheels with such large offsets though - it limits the choice - most replicas are 42 to 45 - the 45 is definitely better.
    ive just pickup up some rs6 reps in 46 offset at 8" and am lowered 30mm with 235/40/18 tyres and it doesnt catch at all.
    when you lower the car the static camber will get bigger, but there is less camber left in roll, so if your car rolls a lot the camber will not increase enough and you will run out of grip - that usually the front end leading to understeer.
    fronts go from about -0.3deg to -1.2 with a drop of 30mm, and the rears ended up to -2, -.8 after some adjustment. the fronts have no adjustment without aftermarket mods but the rears are adjustable. i added adjustable top mounts to give me -1.65 front camber with -30mm drop
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    Feb 2008
    25
    Quote Originally Posted by dunk
    I dnt understand any of this, suppoe il need to wait an see when i get mine. I was thinking 30mm might be better on 18s
    RWD sucks!
    Dec 2007
    175
    Quote Originally Posted by N8KOW
    My friend with RS4 replicas (18 inch) and ET 42 rubbed on contis SC2. He machined the wheels 4 mm (bringing them to ET46) and still rubbed a bit, on S line suspension.....
    Oct 2007
    166
    i have rs4's at et42 and touch wood i have no rubbing even with the car packed out with my mates
    i does seem to be a game of chance some people say they rub whilst some say they dont!!
    probably be best to go higher though if you can
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    Well arches will be getting sorted so I don't have any rubbing problems on my ET45
