Sky InsuranceEM Tuning
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    2.0 TDI 3-door 2WD 18" tyre pressures
    Now I know we've already done many threads on tyre pressures, but I've scoured them and I can't find any definitive answer.
    There are obviously some widely differing recommended tyre pressures depending upon wheel size, engine type, 2 or 4 wheel drive, etc, but from reading the threads, there seems to be different recommended pressures for the same car.
    I've done 4000 miles on my new Contis and the tiny raised rubber bead is still showing around the centre tread which makes me wonder if I've got the pressure too low.
    I'm using the standard 33psi front, 30psi rear, as per the separare 18" label in the fuel flap (which also says 35/39 fully loaded).
    Is there anyone out there with a 2WD 2.0 TDI 3-door with different recommended pressures (preferably with the S-Line suspension, in case that makes a difference too)?
    I wonder if Audi have changed their minds over time and later cars are using higher pressures?
    I don't want to duplicate threads already there with lots of posts of pressures for different variants, but if you've got a 2.0TDI 2wd 3-door, could you tell me if your pressures are different?
    Thanks.
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
    Matt's Avatar
    Jul 2006
    Cumbria
    1,416
    In my fuel cap the only pressures it gives are 38PSI front and 35PSI rear which is what I have been using. The other pressures listed are for different wheel sizes. 38 seems a high pressure but its the only recommendation I can find
    Sold: A3 2.0 TDI 170 S-line | Full leather | BOSE | Phantom Black | Bluefin
    Now: Mini John Cooper Works
    Aug 2007
    437
    Quote Originally Posted by alfiejts
    You have. Raise them by 3psi.
    A3 2.0TDI Sportback S Line 184 Quattro S-Tronic, Mar. 2014 Glacier white. Electric seats, sunroof, se suspension, heated folding mirrors, Reversing camera, Nappa leather, TPMS, Hold assist, Xenon plus adaptive lights with variable active range control, lane assist, Interior light pack, Technology pack, Comfort pack with ACC, park assist & parking system plus
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Thanks Matt. That seems a really big difference. 33/30 for 2004 cars and 38/35 for 2008 cars of the same type....
    I ran with 35.5/32.5 as a trial for my 500 mile road trip last weekend (which seems a reasonable compromise between the two), so I'll see how the centre bead wears after that.....
    Car felt slightly less compliant over motorway ridges and cats eyes, but couldn't notice any other difference...
