Chris NottBadger5
Results 1 to 12 of 12
    Feb 2008
    126
    S3 - getting a good launch
    I have been practicing on getting the S3 "off the mark" quickly and without any "bog down". It seems to me the best way launch an S3 is 4000 RPM let the clutch bite enought to get the car to roll slightly and then fully engage the clutch and floor the accellerator at the same time. This results in a sharp and aggressive launch with a small amount of wheel spin (more of a slight rumbling) and lots of pull without any bog down.
    anything below 4000RPM and it bogs down. This seems quite high RPM to launch on a "stock" clutch, is the S3 clutch "man enough" for this, or are they prone to fail early. Obviously doing the above does not actually give much clutch slip at all as it is almost "side stepping it" but doing it from a point it has monentarily partly engaged rather than from the floor with and earth shuddering snap!
    Or does anyone else know a more clutch "friendly" way to launch the S3 ?
    2007 S3
    Phantom Black
    Bose upgrade
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    about 4K was the best way to launch my R32 when I had it, 23K miles later and it was still running fine.
    J.
    Married and blonde yes, but still a guy with a poor taste in usernames!
    Mercedes Benze E-class 350 sport convertable, black, pacha grey leather, 19" AMG rims, HK stero and a few more toys
    VW Scirocco 2.0Tsi GT with Revo stage 2, evoms induction kit, lowered, short shift, miltek
    BMW 330 Coupe M sport Black, Black leather, Nav and a lot of other options.
    BMW Z4 Coupe Sport in black with a few toys - going friday and gonna be missed by my lad.
    A3 2.0Tdi S-Line DSG. Gone but not forgotten
    richardn's Avatar
    Feb 2008
    81
    Here is my 2c...
    Just before i ordered my S3 the dealership gave me one to drive around for the day to get the feel of it so as it wasn't my car and the sales guy told me i can give it as much stick as i want i tried just about every launching tech i know. The old AWD scooby launch, when you hit the limiter and drop the clutch as fast as you can, definately does NOT work! The car "bogged" and all i could smell for the next 10min was the burning clutch. I then tried doing the same at +-4k with the same drop of the clutch and that just ended up in "bogging". The best result i found was just what you did... Rev to 4k get the clutch to the point just before it bites and then swiftly release the clutch but don't drop.
    Again this is just my 2c from a day of driving it... Will have a better idea in 3 weeks when mine gets here
    Nov 2007
    253
    TBH when you launch a car the clutch is the last thing I worry about seeing as it's a consumable part - knackering diffs and driveshafts worries me more
    I'd agree with you that the 'granny start' is possibly the best way to launch the car as you're loading everything up gradually - feed the revs in trying to minimise wheelspin
    stepping off the clutch may better your launch by fractions of a second but I wince at what it's doing to the car - a number of years back a good friend of mine had a beautiful urQuattro which had been 'lightly' fettled by Kim Collins, it would light up all four wheels if you side stepped it although he did that part trick once too often. I think Kim could have retired on the back of that invoice alone...
    JohnS3's Avatar
    Oct 2004
    3,021
    Does anyone know if the S3 use the dual mass flywheel?
    Feb 2008
    126
    Cheers for the comments, at least we all seem to agree on the best way to launch it (mostly)
    2007 S3
    Phantom Black
    Bose upgrade
    On Boost
    Manchester
    1,756
    Quote Originally Posted by JohnS3
    I think so , i only no that through reading other threads tho!
    p
    Sundoo's Avatar
    Jul 2007
    67
    Launch the S3 without bogging
    Hey Guys
    I did it! I launched the car by dropping the clutch without bogging the car
    The car did spin all 4 wheels and almost flew away
    The way I did it was reving the car to about 4000 rpm but didnt hold it still, i was pumping it so the revs were between 4000 - 4200 rpm. And then I dropped the clutch and gave it full throttle at the same time. Try it
    If you hold it still on 4000 rpm and drop the clutch, then it will bog, so pump the gas pedal so the rpm is around 4000 - 4200 rpm and then drop the clutch.
    Good luck!
    My car is remapped by the German tuner Heron and im driving on 17" rims with goodyear ultra grip at the moment, but it shouldnt change how you launch the car.
    2007 : Phantom Black With Pearl Effect, Leather Seats with White Alcantara, Front Arm Rest, Electric sunroof, Flat Bottom Steering Wheel, Light and Rain Sensor Pack. Heron Chip: +300 HP +400 NM (Castrol RS 10/60 Oil) My car: http://www.bilgalleri.dk/html/gal_vi...099&tipID=2323
    S3-N's Avatar
    Feb 2008
    263
    are you doing it with esp on or off?
    Phantom Black B7 S4 + Milltek
    Sundoo's Avatar
    Jul 2007
    67
    Quote Originally Posted by S3-Nick
    With esp off or else it will bogg.
    Feb 2008
    126
    ESP is only "on" in the wet on my S3
    2007 S3
    Phantom Black
    Bose upgrade
    boggysv's Avatar
    Nov 2007
    572
    A little off-topic here, but not totally unrelated.
    Once done with first gear and wanting to shift to 2nd, do you guys notice it takes forever for the revs to fall? When trying to get the move on quickish, it seems like the only way is to let the clutch slip a little and bog the engine down to match the wheel speed?
    Even in normal traffic, after pulling away from first gear, I have to pause and wait for the revs to fall enough before getting 2nd gear in and continuing smoothly. By this time, all the other automagic cars (and sometimes even vans, trucks and buses) have left me behind, making me look retarded.
    Though, sometimes I get lazy and just plonk it into 3rd straightaway
    What are you guys doing with regards to this, or do I need to go back to driving school?
    World's Fastest S3 Driver - racing old people in toyota camries since 1997 with a 97.6% winning rate.
